Cxman, thanks for the offer on parts, I may get back to you and see if you have something I could use.
Jsjamboree, on motor is seized, not sure about the other one, I will have to take the kick start lever off of one to see if it will kick over at all.
I have the carb apart and soaking, will have to wait on gaskets before I put it back together. The float bowl gasket is dried out and stuck to the bowl, doesn't want to come out. Any ideas for scraping it out? Have tried soaking it 12 hours and using a flat blade screwdriver, no luck. Have used a razor blade, didn't work.
The petcock looks to be ok, however haven't tested it out so I am sure that will bite me in the ass later. The tank has been coated but it is starting to peel. The coating is white, even though in the pictures it mainly shows black, weird, any ideas how to remove the coating and possibly what coating was used to begin with? Maybe the white color is a hint for anybody who has coated a tank before?
