Author Topic: Running CB500 carbs on a CB550  (Read 1141 times)
Offline stillatwork
« on: Mar 17, 2017, 21:18:09 »
Can you do this? I have Keihin 627B carbs off the 71-73 CB500 I'd like to put on a 1976 cb550
Offline stillatwork
Re: Running CB500 carbs on a CB550
« Reply #1 on: Mar 17, 2017, 21:36:15 »
My guess is yes with compensating for the extra fuel the displacement would require. Even more if not stock i.e. Pods and exhaust
Offline irk miller
« Reply #2 on: Mar 17, 2017, 21:36:25 »
They're racked carbs.  The holes would have to line up, or you have to make a custom rack.
Offline cxman
« Reply #3 on: Mar 17, 2017, 21:54:20 »
i have a set of 550 carbs on my 500 so no reason why iot would not work the other way that i know of
but you will need to rejet
1978 CX650 Super Deluxe
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1974 kawasaki 350 bighorn
1983 GL1100 aspy full dress
1983 GL1100 Nekid
and a bunch of others
Offline stillatwork
« Reply #4 on: Mar 19, 2017, 12:50:14 »
What do you mean the holes would have to line up? So rejetting should be ok for use? Any suggestions where's to start with a 4 into 1 exhaust with an emgo cone muffler and uni pods
Offline irk miller
« Reply #5 on: Mar 19, 2017, 12:52:21 »
SOunds like cxman is confirming that they line up.  The carbs are on a rack, so the carbs are spaced according to where the intakes line up.  The two motors would need to be the same to swap carbs.
Offline stillatwork
« Reply #6 on: Mar 19, 2017, 15:11:21 »
Right so you can swap but will need rejet?
Offline stillatwork
« Reply #7 on: Mar 19, 2017, 15:11:57 »
Would the increase in displacement 500 to 550 increase the netting even more? Any thoughts on float height?
Offline cxman
« Reply #8 on: Mar 19, 2017, 16:15:12 »
you will need to rejet for sure
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1983 GL1100 Nekid
Offline stillatwork
« Reply #9 on: Mar 20, 2017, 23:43:55 »
Ordering 120 and 130 mains and 40 slows. Will set stock Cb500f float height. Was checking SOHC apparently these 500 and 550 carbs are pretty similar set up stock so hoping this isn't a big deal to do. Someone stop me if it is. Running uni pods and a canister 4 into 1 exhaust with an emgo cone muffler welded on. I'm open to any suggestions or anyone's two cents
