Author Topic: 2x stroke street tracker - project coming together slowly.  (Read 16640 times)
Offline NoRiders
Re: 2x stroke street tracker - project coming together slowly.
« Reply #50 on: Jul 06, 2018, 13:45:13 »
A bag-o-bits has arrived.
Suzuki SB200 ramdom engine/gearbox parts for £24 just might save me a lot of grief when I come to rebuild. The engine I have is unknown history and has been opened...so it's likely to be missing a part or three.
I've 'invested' in these goodies to good effect I hope :)
PS Is it really dead in here these days?
« Last Edit: Jul 06, 2018, 19:38:48 by NoRiders »
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #51 on: Jul 06, 2018, 14:33:26 »
I dig the CB200 tank.
Sweet find on that VW GT shifter, that would look sweet in my Ghia  ;)
Offline NoRiders
« Reply #52 on: Jul 06, 2018, 14:48:21 »
Thanks, I love the CB200 tank shape....and I plan to use the padded trim as a style feature on the seat/saddle too
GT shifter is for sale....make me an offer, are you UK based?. They're getting hard to find these days, no one stripping the m out and more GTs being restored. It doesn't have the stock GT insert, just a VW key fob badge. Hit me with your best offer fella.
Offline NoRiders
« Reply #53 on: Jul 06, 2018, 19:37:59 »
Cleared the workbench with a sweep of my hand.....screwed a couple of melamine boards to extend the area. All set to get to work.
These are the stock 18mm carbs....anyone know if an upgrade is viable? I do have the tops and sliders...attached to the cables.
I've been looking at the chinese (I know I know) 26mm+ carbs for not a lot. A mate fitted one to a souped up scooter which worked out very well.....any real life, tried it liked it reviews?
Online Brodie
  • Gold Coast, Queensland
« Reply #54 on: Jul 06, 2018, 20:20:07 »
I have used an oko. Not horrible but not as nice as Mikuni.
Offline NoRiders
« Reply #55 on: Jul 06, 2018, 20:35:11 »
Thanx...looking at them on ebay, but wonder how they'd work together...choke etc? Can't see a twin set up anywhere?
Online Brodie
« Reply #56 on: Jul 06, 2018, 20:37:16 »
I used it on a single. The style I had was just a knock off of the TM series. Had a plunger style choke. Not to much of an issue for me. You might be able to swap to the cable style.
Offline farmer92
« Reply #57 on: Jul 06, 2018, 20:39:05 »
You can use mikuni/keihin plungers from a twin model, depending on which copy carb you get.
You can also just pull the chokes on independently, or use:make something like this
https://m.ebay.com/itm/CARBURETOR-CHOKE-LEVER-B-CARB-CARBY-CARBIE-1976-SUZUKI-T500-TITAN-T-500-76/142262793722?_trkparms=aid=222007&algo=SIM.MBE&ao=1&asc=41376&meid=5a1dab1f45a140148c43db414cb9d804&pid=100011&rk=11&rkt=11&sd=282209201140&_trksid=p2047675.c100011.m1850&_mwBanner=1&_rdt=1
One on each carb and a little rod between the two.
Offline NoRiders
« Reply #58 on: Jul 06, 2018, 20:55:27 »
I s'pose using individual choke levers is an option....if I'll need choke at all that is? Looking at the stock carbs there appears to be only one choke lever and mechanism??? I'll be having a closer look. Thanks
Offline NoRiders
« Reply #59 on: Jul 06, 2018, 20:56:06 »
Using other choke mechs is a good idea. Thank you
