Author Topic: 1982 kz440 piston rings  (Read 491 times)
Offline wanted9
« on: Mar 28, 2017, 11:06:07 »
Was wondering what the process is of getting new rings, can some one enlighten me?
Offline diggerdanh
Re: 1982 kz440 piston rings
« Reply #1 on: Mar 29, 2017, 10:02:51 »
Why do you think you need new rings? Before ordering new rings I would pull the top end apart and inspect and measure the bores to see if it just needs honed or if you need an overbore which would mean oversized pistons and rings.
To answer your question: the only place I have been able to find rings is Ebay. NOS is best but there is someone selling new rings from Japan or Taiwan I believe. They seem to have pretty good reviews. If you need oversized pistons and rings you may get lucky and find them on Ebay too. But you may be better off to either search Craigslist for someone parting out a KZ440 or even a parts bike with a good engine you can swap over.
Offline Nebr_Rex
« Reply #2 on: Mar 29, 2017, 17:36:06 »
There is also a German site that has oversize pistons and ring among other things.
Offline tort
« Reply #3 on: Apr 04, 2017, 03:48:57 »
What diggerdanh said.
a) Find a manual.
b) Adjust valves first. Measure compression, if ok then forget about it. If not, could be valves or piston.
c) Open cylinder, measure bore with a special tool you can probably borrow from somewhere (see youtube for example). If the ovalness is in allowed limits (see manual), you can get new rings only. If cylinder is oval, have the cylinder rebored to +1 size and get the according piston + rings.
