Author Topic: cb seven fifty rc42  (Read 1117 times)
Offline BENJAMIN
cb seven fifty rc42
« on: Apr 04, 2017, 05:24:53 »
So back in 2012 i started on my cb seven fifty rc42 café racer Build. Back then i chopped a whole bunch of the frame... A big mistake cos now im struggling with thé subframe. This is how she sits now.
Now i have absolutely no idea on where tot start...
This how i want things to look :
Any ideas? ( I don't have access to a pipe bender. Welding is not a problem)
Sent from my ONE A2003 using DO THE TON mobile app
« Last Edit: Apr 04, 2017, 05:28:03 by BENJAMIN »
Offline brotus
Re: cb seven fifty rc42
« Reply #1 on: Mar 19, 2018, 22:34:04 »
You can buy pre-bent rear "hoops" based on the distance between your existing shock mounts. I would just weld straight tubing from the backbone to the rear hoop.
Offline d9canada
  • Just keep pluggin' every day and it'll get done!
« Reply #2 on: Apr 10, 2018, 00:32:22 »
1+ to Brotus, I'd get the hoop so you can be sure you can align the laterals and hoop.  Also think about whether you want to stash electrics in a box between those rails and if so, make a cardboard mockup and think it through.  Cardboard is cheap.  But don't get "writer's block" - it's not like you've trashed this puppy, just get on 'er.  Spring is coming!
Brian
63 C105T
73 CB350F X2
77 CB400F X2
73 CB500 X2
77 CB550K X3
80 CB650
80 CB650C
Sandcast CB750 #1003245
71, 73 CB750K X5 (help me!)
78 CB750F X2
82 GL500
82 GL500 Interstate
83 CX650 Euro version
81 CB750C
80-82 CB900C X5 one with Motorvation FII sidecar
75 & 77 GL1000
82 CBX
83 Honda 750 Shadow
73 Norton 850 Commando
