Author Topic: 1980 XT500 BUILD  (Read 17644 times)
Offline MCKAY34
Re: 1980 XT500 BUILD
« Reply #50 on: Jun 22, 2017, 06:19:14 »
I had the forks painting gloss black,
got some new fork gaiters and i have just drained all the old fluid and replaced with new fluid.
Offline MCKAY34
« Reply #51 on: Jun 22, 2017, 06:28:36 »
So well at least its starting to look like a motorcycle again. Im currently waiting for a new cam shaft to arrive, so while im waiting i might as well put some of the steering head and forks back together.
I put new tapered bearings in the steering and it feels great, very very smooth. New risers and to be honest im super happy how its starting to look. nice and clean. Cant go wrong with black on black
I bought some new Renthal bars (silver to break up all the black) and could not resist putting them on and start making motorbike noises!!! braap! braap! braap!
Offline MCKAY34
« Reply #52 on: Jun 26, 2017, 07:11:24 »
ok great news.
the new camshaft has arrived, so i will be reinstalling the new one today.
everything went well and installed with no issues.
Offline MCKAY34
« Reply #53 on: Jun 26, 2017, 07:18:12 »
Ok so i need some advice please.
I am not sure how to install the cam chain tensioner, perhaps im over thinking it. im not sure how tight it needs to be.
so i just screwed the smaller one all the way in.
please have a close look at the pic, you will see what i have done. what is the general rule when installing these cam chain tensioners.
Any help would be great, thankyou in advance.
Offline irk miller
« Reply #54 on: Jun 26, 2017, 08:21:06 »
The smallest part in the very center is a floating rod.  The 10mm nut outside of it is the adjuster.  The big nut is the lock nut.  You're not going to over tighten the 10mm to start, but when the bike is running you adjust it until the floating rod bounces 1 - 2mm.
Offline MCKAY34
« Reply #55 on: Jun 26, 2017, 17:11:52 »
Hi miller , that's great thanks for the info.
When you say "bounces" do you mean it will twist back and forth 1-2mm?  And then I just adjust the 10mm nut either in or out until the rod does this?
Offline irk miller
« Reply #56 on: Jun 26, 2017, 18:25:31 »
When the motor is running, the center rod bounces in and out like a sewing needle.  If it's loose enough, it almost looks like it's going to shoot out.  So, you're adjusting until it protrudes no more than 2mm.  You can stick a wrench over it and it will tap the wrench.
Offline MCKAY34
« Reply #57 on: Jun 26, 2017, 19:14:43 »
Ohh ok. Awesome, that is very helpful and a Great description. Thanks mate.  Wish me luck!
Offline MCKAY34
« Reply #58 on: Jun 27, 2017, 07:00:50 »
Ok here is todays update:
I installed a new upgraded oil line today, its suppose to feed more oil directly to the rocker arms.
I set the valves at:
Inlet valve: 0.09mm
Exhaust: 0.15mm
(Instructions from the oil line packaging say that because the engine will be cooler. Exhaust should be 0.12mm but i dont have a 0.12 feeler guage. mine skips from .10-.15)
If anyone has any thoughts on these valve clearance settings please let me know.
(ignore the gasket silicon, when it dries i will be pulling the excess off)
Offline irk miller
« Reply #59 on: Jun 27, 2017, 08:30:10 »
Spec is .07mm - .12mm on intake and .12mm - .17mm on exhaust.  So, you're in the wheelhouse.  I'd get one of these so you always have it to check.
http://www.ebay.com/itm/Motion-Pro-Tappet-Feeler-Gauge-004-005-10mm-13mm-08-0053-/182455268719?epid=917019082&hash=item2a7b2e756f:g:wpIAAMXQlgtRoAsd
