MCKAY34 said:Hi guys, well because the response was so fast and i solved the issue in regards to my last problem. im going to see if we can now fix this problem.
Does anyone know what these wires are for?
They are at the headlight end. I need to know what the 4 in my hand do. and also the 6 in the connection individually. I think the connection is for the handlebar switch block. But i need to know which wire does what.
Again any help would be great.
MCKAY34 said:Hey hillsy,
thanks mate, i will have a play with it. what does +ves mean?
Looks good. You followed the tried and true method of hammers and angle grinders. If you start there you cant go wrong. The hubs, spokes and rim combination looks great.MCKAY34 said:the rear brake arm worked out ok, after a few hits with the hammer and the angle grinder. I slapped some new paint on there, and bought a new spring. looks ok and im sure it will work great!
What are your thoughts?
540Nova said:Looks like good quality environmental splices there.
One thing you'll find, like I did, is the Hi beam indicator on that speedo is BRIGHT! So much so, that I put a piece of tape on it at night, because it kills my night vision!
Sent from my SM-G955U using Tapatalk
Mr Bernzo said:Looks good. You followed the tried and true method of hammers and angle grinders. If you start there you cant go wrong. The hubs, spokes and rim combination looks great.
Sent from my Moto G Play using Tapatalk
