Author Topic: Suzuki GN125 - Tracker - First Project  (Read 3451 times)
Offline parksieNZ
Re: Suzuki GN125 - Tracker - First Project
« Reply #10 on: Apr 13, 2017, 23:26:36 »
Got the electrics back together which took a while as I didn't take enough photos when I was dismantling it. No gas in tank yet as it isn't painted, but new carb on and oil vent filter. Managed to scratch the bloody engine paint while I was working on it. Will have to fix that later
Offline parksieNZ
« Reply #11 on: Apr 13, 2017, 23:28:32 »
Custom paint job on the headlight to match my color scheme.
Offline parksieNZ
« Reply #12 on: Apr 13, 2017, 23:31:39 »
Replaced the crappy old grips and the entire front brake lever and brake fluid until as it was leaking and faulty. Put the new seat on just to see what it looks like, still need to cut the frame and add the rear loop. Also painted and replaced the plastic sprocket cover(Not sure if this is what it is called.)
Offline Hurco550
« Reply #13 on: Apr 14, 2017, 23:37:16 »
Nice work man!
Sent from my SM-G900V using Tapatalk
~ bradj
Offline parksieNZ
« Reply #14 on: Apr 15, 2017, 00:37:56 »
Nice work man!
Cheers man. Powder coating would have been better but too costly for a first build.
Offline parksieNZ
« Reply #15 on: Apr 21, 2017, 20:54:08 »
Tank painted and attached and  rear loop welded to frame. Time to sort out indicators battery box and everything else.
Offline parksieNZ
« Reply #16 on: Apr 23, 2017, 05:25:33 »
Tried some of my first metal fabrication to make some rear indicator mounts and rear light and license mount. Also in the process of building a battery/ electrics box to clear the triangle and tidy electrics
Offline parksieNZ
« Reply #17 on: May 13, 2017, 16:16:50 »
Battery box welded and painted. Rear guard complete. Rear loop also painted.
Offline parksieNZ
« Reply #18 on: May 13, 2017, 16:18:46 »
New rear shocks also arrived today so will be putting them on and then almost done. Anyone reregistered a bike in New Zealand? I'm keen to understand the process.
Offline parksieNZ
« Reply #19 on: May 13, 2017, 20:51:05 »
New shocks on and pretty much finished. Some tidy up to do but otherwise ready to get it registered, sell it and move onto my next project.
