Author Topic: FRANKENHONDA II the 1982 DOHC CB 750F2 Build  (Read 71277 times)
Offline stroker crazy
  • crazy as a fox
Re: FRANKENHONDA II the 1982 DOHC CB 750F2 Build
« Reply #570 on: Dec 26, 2018, 07:08:00 »
Clean!
ďRide like the WindĒ W.H.
Offline teazer
« Reply #571 on: Dec 26, 2018, 11:16:11 »
Rex W builds some great bikes.  Those fins can be built up with weld. You cann't stick the broken bits back on but the stubs can be built up and ground back to stock shape.  Look for a good welder in your area.  Ask around.  Brad's Bikes down in Moorabin (?) may be able to point you to someone who can do it.
Offline brad black
« Reply #572 on: Dec 27, 2018, 04:23:08 »
we used to use a guy called aviation welding in burwood.  not sure if he's still there or not.
maybe ask someone like the head stud development company.
Offline cb250nproject
  • If you can make it better do so
« Reply #573 on: Dec 27, 2018, 05:40:58 »
Cheers for the recommendations.
At the moment Iíve been slowly putting the frame back together.
first cafe build was an incomplete learning experience, more of a test run for the real thing FRANKENHONDA II
« Reply #574 on: Dec 27, 2018, 05:42:15 »
Iím actually wondering if there would be a hydro blasting mob open between now and the time I fly out to blast the barrels.
Offline teazer
« Reply #575 on: Dec 27, 2018, 11:51:12 »
Phil Pilgrim used to have a hydroblast set up when he had his shop.  He may still be in business in Ivanhoe.
Union Jack Motorcycles Pty. Ltd.
P.O. Box 1064, Ivanhoe
Victoria Australia 3079
(Appointment only)
Phone: +61 3 9499 6428
Fax: +61 3 9499 6428
Email: unionjackmotorcycles@gmail.com
« Reply #576 on: Dec 27, 2018, 17:33:39 »
(Appointment only)
Email sent, hopefully heís still operating and keen to take on a last minute job. Otherwise the engine reassembling may get put on hold.
« Reply #577 on: Dec 28, 2018, 16:27:54 »
So yesterday I separated the forks and removed the lower triple and gave it a polish.
I had originally wanted to have the top and bottom triple black but after looking at it I believe having the top and bottom polished frames the headlight better.
The old man is due home from interstate in a few days so we can have a discussion about the top triple that heís going to mill out. Iím excited to see how it comes out.
I contacted Phil about hydro- blasting and he returns to work Jan 2nd so Iíll hold out until then to piece the motor back together.
I may take this opportunity to refurb the rear brake caliper and polish up the engine side covers.
I was speaking to my old man about the paint and he reckons perhaps I didnít shake the can enough. So Iíll go shake the hell out of it and see if the colour comes out any better. 🤞
« Reply #578 on: Dec 28, 2018, 21:22:37 »
I shook the hell out of the gold caliper paint still no joy.
So Iíve decided to rebuild the caliper as is, new seals and pistons, then back on the bike.
Iíve taken two photos one with the original guard on and one without. Iím wondering if I should throw back to the original or leave it without
Offline brad black
« Reply #579 on: Dec 29, 2018, 04:09:15 »
dunno about the plastic bit, but what if you paint the not rubbed areas of the disc black.  might not look so monsterous then.
