Author Topic: FRANKENHONDA II the 1982 DOHC CB 750F2 Build  (Read 71279 times)
Offline cb250nproject
  • If you can make it better do so
Re: FRANKENHONDA II the 1982 DOHC CB 750F2 Build
« Reply #580 on: Dec 29, 2018, 04:43:22 »
dunno about the plastic bit, but what if you paint the not rubbed areas of the disc black.  might not look so monsterous then.
It is huge (that’s what she said anyway) I was thinking of getting the disc drilled out.
Perhaps painting it might help I actually ended up ordering 2 discs in total and got 1 that looked better but was suited to a different hub.
first cafe build was an incomplete learning experience, more of a test run for the real thing FRANKENHONDA II
Offline stroker crazy
  • crazy as a fox
« Reply #581 on: Dec 29, 2018, 07:43:05 »
A good idea from every point of view (except cost!).
Drilled or not, paint would help.
“Ride like the Wind” W.H.
« Reply #582 on: Dec 29, 2018, 17:05:33 »
What do you think it would cost to drill out ?
Offline 1fasgsxr
« Reply #583 on: Dec 29, 2018, 21:26:56 »
If you were in the states there is a guy in OH I think that does it for a reasonable price.
  • crazy as a fox
« Reply #584 on: Dec 29, 2018, 21:28:55 »
If you've got a drill press it will only cost whatever a good quality drill bit costs.
Otherwise you are at the mercy of whoever is doing the work.
This is probably worth a read:  http://www.dotheton.com/forum/index.php?topic=56362.0
« Reply #585 on: Dec 30, 2018, 03:54:04 »
We have access to a mill, I’m just wondering how to ensure the pattern is equal on the disc. I imagine if it was out it would unbalance the disc and create a shudder at speed ?
  • crazy as a fox
« Reply #586 on: Dec 30, 2018, 04:36:00 »
A mill would be the business.
It would take some pretty major irregularity to cause any problem!
Offline Pete12
« Reply #587 on: Dec 30, 2018, 07:47:49 »
Easy to do on a mill. What sort of pattern are you thinking of?
« Reply #588 on: Dec 30, 2018, 10:51:49 »
For the sake of continuity I guess the same as the front disc
Offline hooligan998
« Reply #589 on: Dec 31, 2018, 00:42:27 »
Just out of curiosity, did you drill the front or is that stock for that rotor?  I don't see any chamfering on the holes for the front disk.  Just wondering if that was intentional or not.  Unless I just can't see it in the pic.
