Author Topic: 1975 Honda CB125S  (Read 8907 times)
Offline Sonreir
  • Moderator
  • Oregon
Re: 1975 Honda CB125S
« Reply #20 on: May 24, 2017, 17:25:40 »
Unfortunately, 8v is probably dead for LI-ION. They don't usually charge back up from being that low.
360 stator should fit, but I think the timing marks might be different?
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline vwrabbit
« Reply #21 on: May 24, 2017, 17:27:09 »
Damn. I'll double check disconnected voltage.
Offline kwak250
« Reply #22 on: May 24, 2017, 19:30:10 »
Got the superbike bars mounted upsidedown. Looks pretty good. The wife isn't so keen. She says it looks like a crotch rocket now. Thanks to hillsy's tip, I notched the controls to avoid drilling. Need to notch the right side a little more though.
I need to get better pictures tomorrow.
I like the barsdid you have to replace cables etc with it being lower?
Offline vwrabbit
« Reply #23 on: May 24, 2017, 19:35:53 »
Thanks. I should shorten the cables, but rerouted them for now.
Offline vwrabbit
« Reply #24 on: May 24, 2017, 21:01:17 »
Pulled the battery and replaced it with a large cap in hopes that I could still get it to run, but no love. Only with the battery...
Offline kwak250
« Reply #25 on: May 24, 2017, 21:16:02 »
Try using an AGM battery, it's heavier but can also be place on its side too
Offline vwrabbit
« Reply #26 on: May 24, 2017, 21:18:31 »
Yah, leaning that way. Just ordered a li ion charger thinking I'd keep the WPS, but returning to Amazon and will also return the charger and get an AGM battery.
Offline vwrabbit
« Reply #27 on: May 24, 2017, 22:55:50 »
Ok, did some research tonight. Learned that these bikes won't start if the battery goes flat or is not installed due to the ignition type. Battery required to create spark.  Might just pick up a cheap lead acid battery for now to try to figure out if my charging system is working. My aftermarket regulator rectifier may not be working also.
Offline vwrabbit
« Reply #28 on: May 24, 2017, 22:58:49 »
Started mocking up the seat. Didn't get pics as the dogs were being a-holes so I had to go in for the night.
The seat will only be about 6" wide and about 22" deep total. Seating area will end at about 16". That seems to be where I'm comfortable.
Offline kwak250
« Reply #29 on: May 25, 2017, 01:24:05 »
I'm following
