www.Moto-Madness.com
Author Topic: '69 CL350 resto-mod FINISHED  (Read 933 times)
Offline Dr. Noisewater
« on: May 08, 2017, 23:12:52 »
Hey guys just finished this bike and thought I'd share some pictures I took along the way. I'll briefly describe things but feel free to ask any questions!
So a few years ago I went to a junkyard in search of a particular part, instead I found an empty frame with a pile of parts claiming to be a CL350. The frame and engine were the only original parts, everything else was pulled from various Honda's of the 70's. I sold what I didn't want and began accumulating parts that would fit the vision I had for the bike, but no real progress was made until about 6 months ago. After moving twice and lugging the parts between different states (almost selling it 5+ times) I decided it was time to roll up my sleeves and get serious.
The day I brought it home compared to now:
« Last Edit: May 08, 2017, 23:16:26 by Dr. Noisewater »
Offline Popeye SXM
  • Also used for MX
Re: '69 CL350 resto-mod FINISHED
« Reply #1 on: May 08, 2017, 23:31:16 »
Gorgeous bike. Can we have more pics of the build?
« Reply #2 on: May 08, 2017, 23:34:53 »
Here's the parts breakdown:
- 1969 CB front forks
- 19" CL front wheel w/ drum
- 1972(?) CB350 front fender
- CB500 Twin fuel tank
- 1973(?) CB side covers complete with Honda Dream tank badges
- rear set footpegs from Slipstream Cycle Works
- seat made from old skateboard, then upholstered
- hoop welded & shaped into the rear of the frame
- Cognito moto swingarm extenders welded into the swingarm (1.75")
- the entire electrical system is new with a custom harness from Sparck Moto
- all routine maintenance/tune-up work done (valves, cam chain, etc)
- compression tested 150psi in both cylinders
- completely rebuilt carbs with k&l carb kits
Now for the pictures, and yes I built the bike entirely on my back porch...
« Reply #3 on: May 08, 2017, 23:38:50 »
The fuel tank had some bad dents on the right side. I used a blow torch to heat the dented areas, then pushed the dents out from the inside with a metal rod that I rounded off at the end. I got the surface as smooth as possible, then put a thin coat of bondo to finish it off.
Offline kagraves
    • Kyle Graves Portfolio
« Reply #4 on: May 08, 2017, 23:39:53 »
Nice build! The Bondo job really cleans up the frame mods. Not to mention the factory welds that were pre-existing.
« Reply #5 on: May 08, 2017, 23:41:49 »
I sprayed the frame with John Deere Blitz Black - the best spray paint I've ever used. Tough as nails and always goes on smooth.
« Reply #6 on: May 08, 2017, 23:49:39 »
The fuel tank was a huge process. After fixing the dents I set out to put a solid paint job on it, with a rattle can! I used a cheap Duplicolor for the the base color, then a fancy clear coat to protect from gasoline etc. Plus countless hours of wet sanding and polishing, both for the tank and the side covers.
« Reply #7 on: May 08, 2017, 23:56:12 »
The plastic side covers were terribly pitted when I got them, so I sanded them down smooth before doing the painting process described above.
« Reply #8 on: May 09, 2017, 00:01:20 »
The swingarm extension slugs were somewhat of an afterthought. I was aimlessly browsing online and stumbled upon them, realized I had an extra swingarm, so I decided to give them a shot. The slugs are quality items and have a satisfyingly perfect fit inside the swingarm. I also chose slightly longer shocks in the rear to compensate for the added length. I didn't want the rear of the bike to sag.
« Reply #9 on: May 09, 2017, 00:06:10 »
I found some cheap, tiny LED turn signals on ebay and made little brackets to mount them to the upper shock mounts. I liked them so much I did the same for the front.
