Author Topic: 1974 CB360 Engine Troubles (I think)  (Read 19305 times)
Offline millermatic187
Re: 1974 CB360 Engine Troubles (I think)
« Reply #250 on: Nov 22, 2017, 22:26:43 »
I had a similar issue on a CB360t that is used to have. The float in the right side carb was screwed up. Like the tang was broken off for the float needle. But the right side pipe would get really hot, like it was running super lean. Youíre saying that itís cold/warm points in the direction of an ignition issue, paired with the blue/white smoke being more than likely un burnt fuel. Definitely get to the bottom of it, because that fuel will eventually wash the cylinder walls down and then bad things happen.
Online trek97
« Reply #251 on: Nov 22, 2017, 23:04:46 »
If the tang was broke off float, the needle would drop down and never close.  This would cause fuel level to rise, dumping entire contents of fuel tank onto the ground through the overflow tube.
The bike would run rich, blowing black smoke (un-burnt) fuel.  The pipe would be cooler temperature.
But yes, an overly rich condition can wash cylinder walls.
« Last Edit: Nov 22, 2017, 23:06:30 by trek97 »
« Reply #252 on: Nov 23, 2017, 11:47:20 »
If the needle dropped down.....in my case it was stuck. But anyways, his issue isnít with it running rich, itís getting it to light initially. Removing the one plug wire doesnít change anything. He said after letting it run, the right side is warm, while the left side is hot like itís supposed to be Which is more than likely heat transfer from the other cylinder. But after riding it for a few minutes it runs fine. Like a bad condenser, or a set of points that are set too wide, where you need more current to light the candle. My suggestion is to start with the simple stuff. Fresh plugs, set the valves, cam chain tension, maybe a set of spark plug boots. But if that doesnít cure it, and you have to dive in deeper (coils,points) throw that crap out and step into the 21st century with a modern ignition. 40 years is a long time for Japanese electrical components.
Online trek97
« Reply #253 on: Nov 23, 2017, 12:32:01 »
+1 bro.  I didn't understand from your story, your experience involved a stuck needle.
Personally, I like points ignition.  In my experience,  given just a minimal amount of maintenance, they serve they're purpose quite well.
Until the issue is revealed, I feel theres no reason to recommend a guy just simply start throwing money at it.  New points are like $20, and At $300+ or -?? Solid state ignitions aint cheap for some of us.
« Last Edit: Nov 23, 2017, 12:49:25 by trek97 »
Offline rsjudka
« Reply #254 on: May 06, 2018, 19:10:23 »
Weather is warming up and feel like I finally have her in a decent state. Got the original mufflers on and I gotta say it looks and sounds alot better now.
Thanks everyone for all your help! If anything goes wrong and I get stuck, I'll definitely be back here 😁
Offline rsjudka
« Reply #255 on: May 07, 2018, 23:15:08 »
I have have spoken too soon...
Just got done with the regular maintenance (cam chain, valves, etc) and I'm kind of confused.
So the bike sounds better (quieter engine), get to higher speeds faster, and the bike has no problem getting to 9k rpms (before it maxed out at 7k). But, the bike takes a while to "warm up" and compression is around 130ish both sides.
I would assume lower compression means lower max rpms? Could the low compression be because my valve adjustments are too loose?
« Last Edit: May 07, 2018, 23:25:33 by rsjudka »
Offline irk miller
« Reply #256 on: May 07, 2018, 23:29:09 »
Lower compression is leaky valves or worn rings.  If your tappets are adjusted too tight, it's possible they aren't closing all the way.  Although 130 is not super bad.  It's not as good as 160, but it's not as bad as 90.
Offline rsjudka
« Reply #257 on: May 08, 2018, 01:25:37 »
Does it make sense that I have lower compression but the bike accelerates and has a higher max rpm than before? Or are the two unrelated?
Sent from my Pixel 2 using DO THE TON mobile app
Offline irk miller
« Reply #258 on: May 08, 2018, 01:32:35 »
Compression is certainly related to power.  Though, I would expect lower compression to reduce hp not gain.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #259 on: May 08, 2018, 11:58:38 »
It can be related, yes. If you have your cam timing off by a tooth, you may notice decreased compression at low RPMs, but the power band would be moved further up the range. This may seem like a good thing, but it's not. You might be putting your exhaust valves at risk of contact with the pistons. I would consider pulling the rocker cover (remember to reset valve lash every time the rocker cover comes off) and double-checking that your valve timing is correct.
Audaces fortuna iuvat.
1977 Honda CJ360 - Cafť SOS - Stage Oneô, Cafť SOS - Stage Twoô
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
