Author Topic: Excess Four Hundred (XS400 Brat Build)  (Read 11657 times)
Offline Rusnak_322
    • STUNT BIKE
Re: Excess Four Hundred (XS400 Brat Build)
« Reply #20 on: Jul 05, 2017, 18:06:26 »
Plus the wheel bearings look new, so that would save me an additional $30-ish dollars.
Offline Rusnak_322
    • STUNT BIKE
« Reply #21 on: Jul 06, 2017, 11:16:08 »
Anyone know if you need to upgrade your regulator when installing a Lithium battery if you have a CDI ignition? I read that the Lithium batteries don't like old bikes with higher charging voltage, is there any way to tell what that cut-off is? The bike is a 1980.
thanks,
Offline canyoncarver
  • 'hacking is learning'
« Reply #22 on: Jul 06, 2017, 12:13:05 »
thanks,
Get a new reg/rec, these old bikes need them.   The old ones are crap.
73' The Commando
YZF750/1000R The Fly
KZ 750 Twin
ZRX 1100
KZ400 The Rabbit
KLR650, 69' Norton P11 Ranger, a 65' Atlas, a 60' BSA scrambler, 93" shovelhead chop, an 86' FXR, and an F9 Bighorn
more YZF750R's, more KZ's, a Zephyr750...and the ever unfinished 75' CB550 cafe.
Offline Rusnak_322
    • STUNT BIKE
« Reply #23 on: Jul 06, 2017, 16:46:30 »
My TO DO list
XS400 to Do:
Cut light into hoop
wheels to get blasted and then powder coated / painted
Weld bracket for rear brake master cylinder
Fix starter
Paint tank
Paint frame
Wiring
Rebuild carbs??
Build battery box and electronic holder
XS400 to Buy:
Tires
Tubes
Wheel bearings – Don’t need if painting
handle Bar / Triple clamp vibration plugs
Speedo
Headlight - $77.31
Front turn signals $12.99
Paint / clear
Engine paint
rear brake master cylinder $9.99
Shocks?
Grips
Battery - $114
Headlight mount - $14.99
Exhaust wrap - $11.80
Mufflers - $59 ea
Front master cylinder / Clutch perch
Brake lines - orange
Fork gaiters
Coils??
Chain??
Plate holder
Oil / filter
Regulator
Tank graphics
Orange plug wires
Mirror
Fuel filter / fuel line
F&R Brake pads???
Air filters???
Offline Rusnak_322
    • STUNT BIKE
« Reply #24 on: Jul 09, 2017, 11:33:06 »
Rebuilt the starter motor, turned out to be a big pain. The king bolts holding it together were hard to get off, and then the rebuild kit I bought had way more parts then the starter did. Last, I had a hard time getting the gears to mesh correctly. I didn't know what the problem was, but when I would get it together it wouldn't spin by hand. Finally got it fix, installed and was able to turn the motor over pretty easily.
Offline Rusnak_322
    • STUNT BIKE
« Reply #25 on: Jul 09, 2017, 11:36:25 »
I finally sucked it up and bought a blast cabinet. Got it on Craigslist for $100. It is a Harbor Freight and the reviews on the site said that it took around 4 hours to build, so driving 1 1/2 hours each way to pick it up was worth it.
Tried it out with some 80 grit glass from HF. Works great, wish I would have had it for the last 2 bikes I did. I spent so much time washing, degreasing, and wire wheeling parts to get them ready to paint.
« Last Edit: Jul 09, 2017, 11:38:02 by Rusnak_322 »
Offline Rusnak_322
    • STUNT BIKE
« Reply #26 on: Jul 13, 2017, 16:46:36 »
Got a lot of parts in yesterday.
Headlight. Headlight mount. Mufflers. Exhaust wrap. Small battery.
Got lots more stuff on order, hope to get the wheels painted and tires mounted as well as pull the motor from the frame to clean and the de-tab the frame and paint.
Get close. Mid Aug is the deadline to get it on the road.
Offline vwrabbit
« Reply #27 on: Jul 13, 2017, 22:29:37 »
Those blasted parts look great.  Did that wheel fit in the cabinet OK?
Offline Rusnak_322
    • STUNT BIKE
« Reply #28 on: Jul 13, 2017, 23:18:07 »
Yes, that is a 18" dia wheel and it fit with plenty of room to move it around. I did need to take it out to flip it.
Offline vwrabbit
« Reply #29 on: Jul 13, 2017, 23:48:42 »
Nice. Going to have to find one of those cabinets.
