www.Moto-Madness.com
Author Topic: RD400 - Back from the Dead  (Read 14531 times)
Offline AimlessMoto
  • Blood, sweat and beers.
Re: RD400 - Back from the Dead
« Reply #20 on: Jun 06, 2017, 00:17:32 »
Really? I guess so. Just to get it running and riding at least. Could always fix it later if the need is there. I also did a little research sinse posting and found 86-09 Banshee pistons are a direct fit... Fast From The Past sells Wossner piston kits at 65.5mm for $99 a cylinder. Specific to the RD400.
At least I know there's options... but I'll call up wiseco and see about some new rings for now.
Offline clem
  • static fluff
« Reply #21 on: Jun 06, 2017, 11:18:12 »
Go and check out economy cycle. Pro x, wiesco, etc. They are out there. To use banshee piston you will need to file down the skirt on the intake side but that's no big deal.
Sent from my SAMSUNG-SM-G920A using DO THE TON mobile app
Offline AimlessMoto
« Reply #22 on: Jun 06, 2017, 17:00:31 »
I just bought a better bore-gauge... going to double check when that comes in. Then I can bring them to a machine shop and see what they recommend...
I found a 65.25mm Wiseco set for the Banshee for $170 shipped. And Amazon has 65.25 or .50 Pro-X for $70 a piston kit.
Not so bad after all. Hopefully I can get away with the 65.25mm overbore.
Offline AimlessMoto
« Reply #23 on: Jun 06, 2017, 19:17:48 »
Got an appointment for Monday to meet up with an old-timer machinist. Should be a quick flip.
Offline AimlessMoto
« Reply #24 on: Jun 07, 2017, 00:18:25 »
Gave it a legit attack tonight.... was able to borrow some better tools. Checked each cyl 9 ways, each piston 3, and re checked the rings. As you can see in the photo, the bottom of the left cyl is 65.16mm... but the top isnt too bad. This was throwing off my shim measurement with the piston 3/4 of an inch down in the bore.
BUT if you look at the top right... I tried the left rings in the right bore, and got .002" larger than the right ones... so not only are they gapped wide, but the cylinder is also large enough to double that measurement.
Maybe new rings will suffice? But 65.16 means im getting aweful close to 65.25 anyway...
Still bringing it to the machinist... but should I just bite the bullett and order pistons anyway?
My gut says yes... and so does my OCD. Lol.
Offline teazer
« Reply #25 on: Jun 07, 2017, 02:04:31 »
If your machinist is an auto machinist, he will probably have a really good bore gauge and will be able to advise what needs to be done. If teh budget will stand it, get a pair of pistons.  He can tell you if it will clean up at 65.25 or if he needs to go to 65.5.  Sounds like it's close to needing a rebore and hone and if the crank is getting new seals maybe a good idea to go with fresh bores that are not tapered and out of round.
Offline AimlessMoto
« Reply #26 on: Jun 07, 2017, 12:32:17 »
Thats the thing. I was hoping to get the pistons before going to the shop. Then he can just match them.
I think im just going to buy the 65.25s from Pro-x because theyre cheaper. If I need to, I can return them through amazon. If he tells me he needs 65.50s, ill return them and spend the extra on wisecos.
Offline JSJamboree
  • DTT BIKE OF 2016
  • Weird Indy Kid
« Reply #27 on: Jun 07, 2017, 14:07:00 »
I saw RD heads in the uploaded pics feed, had to stop in and see whats going on in here
Offline AimlessMoto
« Reply #28 on: Jun 07, 2017, 16:40:22 »
Lol, just looked through your RD build. Amazing work! You live in VT? Im in MA.
Online Maritime
« Reply #29 on: Jun 07, 2017, 16:42:22 »
JSJamboree is one of the weird Indy kids, but I see how you would think he's in VT with Stowe's brewing avatar, happens to be his last name ;D
