Author Topic: Latest project - Suzonda WTF200/2 in progress  (Read 13952 times)
Offline NoRiders
Re: Latest project - Suzonda WTF200/2 in progress
« Reply #100 on: Apr 28, 2019, 17:57:44 »
Replacement NSR125 forks/wheel/caliper installed....just need new taper bearings. And another top yoke.
Sprocket/swingarm alignment working out OK I reckon.
Getting closer to final mount position for the engine.....any ideas on engine inclination datum?
That's all for now
Offline NoRiders
« Reply #101 on: May 12, 2019, 19:51:03 »
It's rolling...:)
Aligned the rear wheel using threading and extra nuts....I now know the size of the spacers.
Stage1 engine mount fabrication..
Offline beachcomber
  • TJ - Beachcomber
« Reply #102 on: May 14, 2019, 17:54:02 »
One cool ride !!!!! 8) 8)
Offline NoRiders
« Reply #103 on: May 20, 2019, 10:47:10 »
When you're at a VW event and score a tyre cheap. 10 bargain 110/70x17" Kingstone tracker style tread pattern should do the job of sunny runs down the coffee shop I reckon ;)
Also incoming: 3x25mm flat bar for enging mounts.
Headlight mounts.
Moving along....
Offline NoRiders
« Reply #104 on: May 22, 2019, 06:54:10 »
Front disc cleaned up well enough :)
Offline NoRiders
« Reply #105 on: May 23, 2019, 10:49:25 »
GT200 5xspeed, electric start engine....incoming.  ;D
