Author Topic: Latest project - Suzonda WTF200/2 in progress  (Read 13964 times)
Offline NoRiders
Re: Latest project - Suzonda WTF200/2 in progress
« Reply #70 on: Dec 13, 2018, 14:08:05 »
New fork stem in solid stainless = 20mm. :)
Offline NoRiders
« Reply #71 on: Dec 18, 2018, 14:24:30 »
Decals incoming :)
Offline NoRiders
« Reply #72 on: Dec 21, 2018, 19:42:22 »
New stem installed.
Offline pitobread
« Reply #73 on: Dec 21, 2018, 20:15:21 »
I saw those stickers posted in a facebook group I just joined,  neat build.
Offline NoRiders
« Reply #74 on: Dec 21, 2018, 21:02:02 »
THANK you.
He's OK.  Worked with me from my rough outline to the finished product. He also supplies factory decals too.
Sent from my SM-J320FN using DO THE TON mobile app
Offline NoRiders
« Reply #75 on: Dec 22, 2018, 14:58:27 »
.....just might work as a flat tracker arse end on the Suzonda ;)
Something different from the usual perhaps?
Offline beachcomber
  • TJ - Beachcomber
« Reply #76 on: Dec 23, 2018, 18:25:54 »
That's great info - post it up in the UK suppliers section ?
Offline NoRiders
« Reply #77 on: Dec 25, 2018, 06:31:36 »
Where's this UK suppliers section you speak of Beachy?
Offline NoRiders
« Reply #78 on: Jan 01, 2019, 20:18:31 »
So, after a good few hours browsing various Honda model discs I think I might've found a workable alternative disc that meets the requirement.
A CBR250 could be it. The centre mounting looks likely to be the same as the NSR disc mount I reckon?
The NSR disc measure PCD 12mm hole to hole and the centre bore 10.5mm with what looks like a 5mm offset. I'm not too bothered about the diameter as that can be allowed for when mounting the Brembo.
Don't suppose anyone has a definitive answer out there? Cheers Colin
Offline beachcomber
  • TJ - Beachcomber
« Reply #79 on: Jan 03, 2019, 06:27:07 »
Under "Recommended - UK" - I'll try to change the title to make it clear !! A bit ambiguous.
