Author Topic: The Van Van - '73 Suzuki RV125 "tracker"  (Read 11034 times)
Online advCo
  • Nick Ol' Eye
    • adventur Studios
« on: Jun 15, 2017, 11:28:49 »
Without further ado, I present to you the Van Van!
Canyoncarver picked this old girl up a while back, and a while later I was searching for a CT70/90 I remembered he had it stored. With slightly larger tires and a 125cc 2 stroke motor, the RV125 is a cool alternative and should be a blast. We chatted about it and I made a plan to go out and grab it from him.
Here I am sitting on it in the canyoncarver shop. It's bigger than I originally thought, the beefy tires create a weird illusion that it's a smaller bike than it is, in photos anyways.
Since we flew out, rented a car and planned to stuff the bike in the back, disassembly commenced.
Fit like a glove. Good thing our rental ended up being an SUV. Everything is in there with the exception of the front wheel (woops!) but more on that later.
Back at the shop
I was going to put it back together, fix the motor and ride it but since it was already more than halfway disassembled, I figured why not just go all the way and do it right. So disassembly commenced.
Online advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #1 on: Jun 15, 2017, 11:39:35 »
So the motor...yeah. Some PO had busted the cases on a rock or something, and "fixed" it with a shitload of RTV and probably a piece of metal. Well that didn't last and here we are. It's on the flywheel side and that is undamaged. I picked up a set of TS125 cases for dirt cheap (TS125 and RV125 motor are basically identical during the years that the RV125 was made) and  a good condition stator cover from eBay first thing.
Other than that, the motor turned freely and feels like there's good compression there.
No head gasket?
More damage to the stator cover. Upon further inspection this thing was dropped pretty hard on the left side.
That's supposed to be straight...
PO (not canyoncarver  ;D ) did some nice work
Torn down just about all the way. I made a DIY crank puller tool out of some 1/4" steel plate, some 6mm threaded rod and nuts, 10mm threaded rod and a threaded bung that Mr. E whipped up (for a different part of this project).
After trying it once or twice and realizing I forgot a crankcase joining screw (doh) the cases split smooth as butter.
And that brings us just about up to date with where I'm at. The new cases have been cleaned up and I'm beginning to swap transmission and other internals over.
Online advCo
  • Nick Ol' Eye
    • adventur Studios
Re: The Van Van - '73 Suzuki RV125 "tracker"
« Reply #2 on: Jun 15, 2017, 11:45:46 »
While the motor is in progress, I have been sourcing parts and prepping for refinishing. Built a little spray booth out of recycled materials back behind the shop so I don't coat everything with overspray. It will get sheathing and probably get expanded later, but I needed this up quick to get moving so it's nothing special.
Prepped the frame and swinger to test out the booth. Works killer.
And we're up to date.
Offline mrsadvco
« Reply #3 on: Jun 15, 2017, 11:49:16 »
 Wooo!
Offline Hurco550
« Reply #4 on: Jun 15, 2017, 12:40:17 »
you know im in! That thing really is way bigger than I had pictured!
~ bradj
Kamn
  • Guest
« Reply #5 on: Jun 15, 2017, 13:16:27 »
Nice work Nick, thats gonna be a fun little ripper when youre done
Offline Maritime
« Reply #6 on: Jun 15, 2017, 13:31:58 »
Wow. nice. there was one of these for sale local and I thought it was ct70 size, that's a full size ride. now I wished I had bought it with the $$ I don't have.
Offline canyoncarver
  • 'hacking is learning'
« Reply #8 on: Jun 15, 2017, 16:59:13 »
Hell yeah buddy!  I knew you'd be the guy to take this project and run with it.  And thanks for not implicating me in the po's mess....lol....
73' The Commando
YZF750/1000R The Fly
KZ 750 Twin
ZRX 1100
KZ400 The Rabbit
KLR650, 69' Norton P11 Ranger, a 65' Atlas, a 60' BSA scrambler, 93" shovelhead chop, an 86' FXR, and an F9 Bighorn
more YZF750R's, more KZ's, a Zephyr750...and the ever unfinished 75' CB550 cafe.
Online advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #9 on: Jun 16, 2017, 13:42:58 »
More progress on the motor. This gear slip fit into the bearing. I gently tapped it out of the old case, stuck it in the freezer for a couple hours, then heated the bearing and it slid right in.
New crank seal for this half, transmission and gearshift assemblies back in place and lubed up.
Now I cleaned up the other half of the eBay case. The gasket surface is pretty nicked up from whoever was in here before. This motor uses a fiber gasket between the case halves... but would it be a good idea to use a super thin coating of yamabond to make sure they seal up nice and tight?
