Author Topic: Looks like a cafe  (Read 2148 times)
Offline datadavid
Re: Looks like a cafe
« Reply #10 on: Jul 13, 2017, 07:47:40 »
Cool project, I'm in, I dug your Yamaha chop build.
Yea i dug it too til it started eating  regulators out of nowhere and refuses to stop no matter what i do to it!
Better stick to simple british electronics..
Offline surffly
« Reply #11 on: Jul 13, 2017, 07:54:31 »
I just bought it last week, barely got around to reading up on welding reynolds 531 steel..
Why are you welding on it?
Offline datadavid
« Reply #12 on: Jul 13, 2017, 07:57:38 »
There are no engine mounts whatsoever, left downtube is cracked, welded and cracked again, and headstock is bent..
The downtube looks like it has been badly mig welded by some clueless asshole, then ground down very carelessly. These pipes are thin wall as it is already, so i need to replace a part of the downtube, and 531 tube is no longer available so i will see if i can get some 541, or just 4130 chrome-moly and possibly weld it. Otherwise i will just make some slugs and braze it back together.
« Last Edit: Jul 13, 2017, 08:00:31 by datadavid »
Offline teazer
« Reply #13 on: Jul 15, 2017, 11:47:03 »
It would originally have been SIFBronze welded.  SIFBronze is still available in the UK but not so much in the US. Silicon bronze has a slightly lower strength but should be OK if you can't get Nickle bronze filler (welding) rods.  They were Oxy welded not MIG or TIG originally.
541 or T45 or 4130 from germany should be Ok.
The frame does look shorter than the average Triumph cradle.  I wonder if it was made for a T100.
 Can you tell if it was made by the Rickmans or by Pat French? I wonder if it was a one off custom frame.  Or could it be a locally made copy of a Rickman to take some strange Swedish single motor?
Offline datadavid
« Reply #14 on: Jul 15, 2017, 12:43:08 »
P.O didnt have much info other than it being registered and used with a triumph engine. I guess since the a65 lump fitted well in there a t120 should not be a problem either.. but the papers say t100, so its probably made just for that.
I think i have some nickel bronze alloy filler left from my bronze tank from the previous project, but since im a welder i can get all that stuff for free basically.
Offline datadavid
« Reply #15 on: Jul 20, 2017, 09:49:02 »
Oh, and bronze welding is actually a brazing process, since it does not fuse with the base material as most here probably are aware, difference to brazing is that bronze welding relies on the weld bead for structural strength, whereas brazing uses capillary action mostly.
I have actually already tried pulse-tig welding bronze on my last project, so there i fiddled a bit with joining steel bits with pulse welding bronze filler rods. Also did a little wear coating on gearbox parts. Worked excellent!
