Author Topic: Yamaha 12v Conversion  (Read 381 times)
Offline firebane
  • braaaaaaaaaaap
« on: Jul 17, 2017, 16:39:22 »
I am in the processs of converting from 6v to 12v on my bike and did a lot of research and looking and think I have what needs to happen to make this work.
I plan to run a led headlight on its own switch so its on only when I need it. I also will be running led turn signals as well as a led tail/brake light. This should keep as much to a minimal draw as necessary to not put much of a load on the system.
Attached is the wiring diagram I think should work.
Offline Sonreir
  • Moderator
  • Oregon
Re: Yamaha 12v Conversion
« Reply #1 on: Jul 20, 2017, 23:32:36 »
You need the fuse between the positive side of the battery eliminator and the toggle. The R/R should go straight to the positive side of the eliminator and not be fused. The battery eliminator's negative side should be grounded and not going anywhere else.
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline firebane
  • braaaaaaaaaaap
« Reply #2 on: Jul 21, 2017, 01:56:59 »
Good catch on the negative of the battery eliminator I would have done that instinctively just missed on the drawing. Will alter fuse location though.
Thanks
