Author Topic: GS 750 Cafe - Wiring Left Switch HELP  (Read 1564 times)
Offline Sonreir
  • Moderator
  • Oregon
Re: GS 750 Cafe - Wiring Left Switch HELP
« Reply #10 on: Aug 03, 2017, 15:54:32 »
You can, but you need to be sure your headlight is on all of the time, or you might burn out your regulator.
If you leave them disconnected, you won't have full charging power and your battery might die.
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline arisr80
« Reply #11 on: Aug 03, 2017, 16:09:27 »
If i run 2 seperate cables from the lights and connect them together it will make any difference?
Offline Sonreir
  • Moderator
  • Oregon
« Reply #12 on: Aug 03, 2017, 16:11:29 »
Unfortunately, it doesn't work that way.
In the stock switch, these wires were connected when the headlight was turned on and then disconnected when the headlight was turned off. I don't know of any aftermarket switches that can do this.
You can use a relay to do this, but I would just connect them together and get a modern regulator/rectifier.
Offline arisr80
« Reply #13 on: Aug 03, 2017, 16:17:11 »
Thank you very very much!
By modern regulator/rectifier you mean something lile this?
Offline Sonreir
  • Moderator
  • Oregon
« Reply #14 on: Aug 03, 2017, 16:20:56 »
Yes. That will work.
We also have one on our website for $45 ($10 shipping costs). Our version is LI-ION compatible, too.
Offline arisr80
« Reply #15 on: Aug 03, 2017, 17:25:15 »
Thankssss!!! I will let you know!
Greeting from Mykonos
Offline arisr80
« Reply #16 on: Aug 06, 2017, 17:37:27 »
Hello again!! I will need a little bit more help from your expertise.
I would like to wire a new ignition switch.
My original old switch has 4 wires and two positions: OFF - ON - Parking Light
Red - 12v power
Orange - probably gives power to coils, speedometer etc
Grey - parking light
Brown - tail light
My new ignition switch has also 4 cables:
Red - power
Black - ??
Black & White - probably ground
Green - ???
When i use the mutlimeter i see that red and black are together when is on and black/white and green are together when is off
The new switch has off and on only.
Any help how i will wire everything together?
Thanks a lot,
I really appreciate your help
Aris
Offline Sonreir
  • Moderator
  • Oregon
« Reply #17 on: Aug 06, 2017, 18:32:30 »
From new switch to old switch:
Red-> Red
Black -> Orange
Skip all of the other wires.
Offline arisr80
« Reply #18 on: Aug 06, 2017, 21:42:55 »
