Author Topic: Cx500  (Read 2987 times)
Offline Xs7501978
Cx500
« on: Jul 28, 2017, 19:52:16 »
So ive been looking at cx500 and I love them the possabilities with these bikes are endless, I found one not running for $500. His description is "I have a 1980 cx500 motorcycle needs carburetor work and a little too motor turns over been inside not outside have paperwork to get title tires look decent." My question is...is this a good buy? I don't mind the non running bike as long as its not an insane amount to get it running again.
Offline cxman
Re: Cx500
« Reply #1 on: Jul 28, 2017, 20:47:29 »
make sure it turns over
do the stator test see if the source coils are good or if you will have to get a ignitec or replace the stator
1978 CX650 Super Deluxe
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1974 kawasaki 350 bighorn
1983 GL1100 aspy full dress
1983 GL1100 Nekid
and a bunch of others
Offline Xs7501978
Re: Cx500
« Reply #2 on: Jul 28, 2017, 21:34:13 »
Hmm okay is that all that I should check, he said the engine turns over so I'm going to check it to be safe, I'll probably bring some starting fluid to see if I can get a little roar out of it without doing any work but who knows. and I'll for sure do that check, thanks, I'd never heard of it before(obvi a noob here lol)...anything else? I mean im buying it as a project bike but I don't wanna be screwed into a bad deal.
Offline cbrianroll
Re: Cx500
« Reply #3 on: Jul 28, 2017, 21:53:55 »
500 is cheap, test as cxman says, research triple bypass, elec cam conversion, I miss mine alot.
Offline Xs7501978
Re: Cx500
« Reply #4 on: Jul 28, 2017, 22:20:19 »
I have an xs750 now will there be a big power loss with the 250cc loss?
Offline cxman
Re: Cx500
« Reply #5 on: Jul 29, 2017, 08:21:33 »
20 hp loss ten mile an hour top speed if they are both running right
the stock cx gets better gas mileage
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1983 GL1100 Nekid
Offline Xs7501978
Re: Cx500
« Reply #6 on: Jul 29, 2017, 16:03:52 »
Alright. Is that all I need to check?
Offline ChopperCharles
    • Modified Motorcycles by Chopper Charles
Re: Cx500
« Reply #7 on: Aug 01, 2017, 18:35:23 »
Well, the rated horsepower for the XS750 is 64, and the rated hp for the CX500 is 50. In reality, they're both likely far less at the rear wheel. 14hp difference in specs, probably 2-3hp more loss at the rear wheel on the Honda due to the shaft drive. That said, the CX500 has plenty of power for cruising and passing, and an easily attainable 105mph top speed. (It's geared loooow!) What you lose in horsepower you'll gain in reliability. CX500s are 200,000 mile motors. XS750s were 20k mile motors. They had problems with primary chains stretching, cranks going south, leaking base gaskets, exploding gearboxes (especially 2nd gear), and all the standard Yamaha electrical problems from that era. (Low quality wiring that corrodes heavily inside the insulation)
For the CX500, once you have the bike sorted out maintenance is minimal and issues are few and far between. If you do need to do major work on the bike (cam chain, starter clutch, or stator), the whole engine (with radiator, headers, and collector attached) drops strait down onto the ground after removing six bolts. (Seven for CDI models) The back cover can then be removed (with radiator and exhaust still attached) and those parts replaced without even moving the motor off the jack. To replace a head gasket, all you have to do is remove the gas tank and one coolant pipe, and the head comes right off. SUPER easy. Valves can be adjusted in 15 min without removing a single part other than the valve and inspection covers.
If you want more power, the CX650 (actually 673cc) motor will bolt into the 500 frame with some modifications. That motor is rated 65hp from the factory.
Charles.
Offline Xs7501978
Re: Cx500
« Reply #8 on: Aug 27, 2017, 21:50:58 »
In case anyone's curious. Didn't get it, I got distracted with other bikes.
