Author Topic: Project CB350F cafe brat  (Read 8575 times)
Offline stubsryan
Re: Project CB350F cafe brat
« Reply #20 on: Mar 07, 2018, 07:44:51 »
Just bought a sandblaster and started blasting a front wheel to see how it goes. Looks like itís going to do the job fairly well
Offline stubsryan
« Reply #21 on: Mar 07, 2018, 07:46:01 »
Another 1
Offline stubsryan
« Reply #22 on: Mar 08, 2018, 03:44:33 »
So I did some more blasting today and found some rust holes in the rim. Iím now thinking of getting some new rims and spokes from AliExpress which might be 300 clams or so. Iím not sure what size to go for. I believe the front is 1.6 x 18 and the rear is 1.85 x 18. I would like fatter for looks but also for cornering. Iím more a fan of the corners than straight line speed. Color combo will be black rim, stainless spokes and a black hub. Does anyone know what is reasonable to upgrade the size to? Is 2.15 front and 3.00 back too big? Thanks. Oh and here is a photo of the rims. Aluminium cheapies
Offline stubsryan
« Reply #23 on: Mar 08, 2018, 04:29:51 »
I may have spoke before I really thought this through. 3.00x18 is really big. Alternatively I can get 2.15x18 for the front and back. Not sure if thatís ok for the front though 🤷‍♂️
Offline farmer92
« Reply #24 on: Mar 08, 2018, 07:10:45 »
Depends what tire size you want.
I wouldnít go over 100mm in the front, or 120 in the back.
To wide makes it harder to push into corners, not as fun as a bike that can just be tipped in.
Hereís a rim size cheat sheet
2.15 in the front and a 3 in the rear should be okay.
« Last Edit: Mar 08, 2018, 07:12:55 by farmer92 »
Offline stubsryan
« Reply #25 on: Mar 08, 2018, 08:30:26 »
Thanks for the help mate ‍♂️
Offline Integra99
« Reply #26 on: Mar 08, 2018, 09:22:19 »
I'm running 2.1 / 100 front and 2.5 / 110 rear.. I could fit a 120 fear but dont want to affect the handling.
It looks ok..
Offline stubsryan
« Reply #27 on: Mar 08, 2018, 09:22:43 »
So front will be 2.15x18 with 100/90 tyre.
Rear will be 3.00x18 with 120/90 tyre. Also think Iím going with the Pirelli sport demon. I hope this works out ok. Now I need to measure the existing spokes and then order it all and stop procrastinating about the other jobs I have to do
Offline stubsryan
« Reply #28 on: Mar 08, 2018, 09:25:08 »
It looks ok..
Looks good! I canít seem to find a 2.5x18 for the right price so I stepped up a size. Finger crossed it will be ok. Hopefully I can find a 2.5 rim and I will do what you have done
Offline stubsryan
« Reply #29 on: Mar 08, 2018, 09:29:43 »
It looks ok..
Cool bike! How do you go with Cooling having the engine painted? Iím soda blasting soon but not sure if I should should paint the cylinders and valves..
