Author Topic: Ever see a chopper with a leaf spring rear end? (XS650)  (Read 1603 times)
Offline ChopperCharles
    • Modified Motorcycles by Chopper Charles
I was digging through old photos, and found this bike from my 2012 trip to Charleston, SC. I've never seen anything quite like it, and except for the fact it's an XS650, I really dig it!  I love unique chops, and this is visually stunning (at least to me). I wonder how it handles...
Charles.
Re: Ever see a chopper with a leaf spring rear end? (XS650)
« Reply #1 on: Aug 10, 2017, 13:58:27 »
Here's a couple more.
Charles.
Offline Redbird
  • Dolor est Magister Optimus
« Reply #2 on: Aug 10, 2017, 16:39:59 »
To me it looks "Hodge Podge" with the modern forks.
I would've followed the theme up front with a leaf sprung fork.
Something like this...
When you are Dead, you don't know that you are Dead. It is difficult only for Others.
It is the same when you are Stupid.
Offline stroker crazy
  • crazy as a fox
« Reply #3 on: Aug 10, 2017, 17:58:56 »
Probably OK in a straight line … until you hit a bump!
Crazy
“Ride like the Wind” W.H.
Offline cxman
« Reply #4 on: Aug 10, 2017, 20:17:54 »
charles the geometry of the rear hoop and the leaf spring does not allow the swing arm to move
its a hardtail very unusually done
you can compress the leaf spring in direct compression it would have to break to compress
but its neat
1978 CX650 Super Deluxe
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1974 kawasaki 350 bighorn
1983 GL1100 aspy full dress
1983 GL1100 Nekid
and a bunch of others
Offline crazypj
« Reply #5 on: Aug 10, 2017, 22:35:53 »
Isn't the spring mounted to te frame? If so, it will move but without any form of damping (other than leaf friction) it would be very ....interesting?
Best thing I ever overheard
Brian Morgan, 1982
« Reply #6 on: Aug 11, 2017, 03:57:47 »
Spring is mounted to the frame, not the swingarm. If you look, you can see the spring mounted to a piece of metal that takes a sharp turn towards the front of the bike. The leaf itself is attached to that piece of metal, and to the upper mount above the fender. It was definitely not a hard tail, it appears to be an operational suspension.
Charles.
« Reply #7 on: Aug 11, 2017, 04:00:05 »
Also, if you look at the two photos that show the spring up close, you can see a bolt that is contacting that bent area. I'm wondering if that bolt is to adjust the ride height. It's not really doing anything else, sitting there...
Charles.
Offline cxman
« Reply #8 on: Aug 11, 2017, 09:08:25 »
it will apply way more compression than forward arc
the arc of travel is way off
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1983 GL1100 Nekid
Offline crazypj
« Reply #9 on: Aug 11, 2017, 11:35:59 »
Yep, it's weird enough to get talked about. Pretty sure the operating rods will break as suspension operation is going to try and bend them. Should have had pivots on swing arm so they can change position as suspension moves. As is, suspension movement is trying to straighten spring (push upwards) rather than 'bend' it as in normal operation (I know I didn't explain that very well  :-[ )
 One thing that is very noticeable, the cheap pods are distorted because they cant flow enough so get 'compressed' by atmospheric pressure
« Last Edit: Aug 11, 2017, 11:39:08 by crazypj »
Brian Morgan, 1982
