Author Topic: BMW R90/6.. un-farkle to re-farkle  (Read 11517 times)
Offline ridesolo
  • You only bear responsibility for your own actions
Re: BMW R90/6.. un-farkle to re-farkle
« Reply #20 on: Aug 17, 2017, 22:25:43 »
Dang, brother, Kim Kardashian could fit on there w/o overhanging!   ::)
“Fight on and fly on to the last drop of blood and the last drop of fuel, to the last beat of the heart.”
— Baron Manfred von Richthofen
Please check out:  http://www.VetTix.org
This is cooking away out in the shop:
'75 Honda CL378: http://www.dotheton.com/forum/index.php?topic=56547.0
This is an on-going Non-Motorcycle saga:  http://www.dotheton.com/forum/index.php?topic=71319.0
This one is FINALLY done: (!)
'70 Rupp Roadster: http://www.dotheton.com/forum/index.php?topic=67459.0
Offline Hurco550
« Reply #21 on: Aug 27, 2017, 21:59:39 »
Top end put back together with fresh push rod tube seals and gaskets, and the fresh carbs to boot. I didn't do rings at this point as I didn't have the scratch and they were both pushing 145 cold psi per side. If I end up starting to blow smoke, ill do it then, but for now, it'll do. I put er together, clicked the starter and away she went. I'm sure it will need a carb sync, but that will have to wait til tomorrow.
"If you want safety and sanity don't mess around with choppers to begin with and don't come crying to me for recommending something that broke down the line. You're going to be the "builder" so use your own judgment and build to you own personal levels of safety and sanity." - Chopper Handbook
Offline Hurco550
« Reply #22 on: Aug 29, 2017, 22:18:57 »
 Time to start syncing the carbs. One known method on airhead bmws is to short out one side then the other using spark plug short rods and a screw driver to the head, until it runs evenly on both. I'm sure this is nothing new to most of you guys, but I figured I'd share my carb sync short out rods. I didn't have the time to wait on a set to order them, and this method is much cheaper. All told I think I have around $7 in the pair. I used two 4 mm by 60 mm long bolts with the heads cut off, two coupler nuts and four standard nuts (all 4mm) as well as a piece of 3/16 inch inside diameter brass tube cut into two equal lengths around 50mm long. All materials  where in the hardware section  of Lowe's. The coupler nut is recessed on the threaded rod enough to screw over the spark plug. I also used two old spark plug thread on terminals. The standard nuts  just act as lock nuts  to keep stuff  from coming apart. These do fit on both Bosch and NGK caps.
Also made up a set of Gatorade bottle vacuum sync gauges. Of course as soon as I went to start it the battery was dead. Oh well, one more thing to chase down lol
Offline Hurco550
« Reply #23 on: Aug 30, 2017, 18:20:54 »
New shoes came in the mail today.
Offline Hurco550
« Reply #24 on: Sep 02, 2017, 01:19:55 »
 The Gatorade bottles were just a bit too large in volume, so I tried a different route for syncing. I had a set of actual gauges on order, but for the second time this month, for whatever reason, the eBay order got cancelled. Oh well.
Off to harbor freight for a $10 Vacuum gauge (with coupon of course) and a $4 aquarium splitter valve from the big box store. I had to drill out and remove the check valve from the splitter, but other wise it worked well. It would be easier to do with two separate gauges for sure, instead of having to block one off and work back and forth, but oh well, it worked and the job is done I'm pretty sure.
Offline trek97
« Reply #25 on: Sep 02, 2017, 07:15:16 »
Dude, rather than spend the $4 on the "aquarium splitter".  I woulda loaned you another $6 for the second gauge.   ;)
Offline Hurco550
« Reply #26 on: Sep 02, 2017, 12:32:00 »
Ha, valves are needed either way to dampen the vacuum pulse, and not buying the second gauge wasn't a $6 issue, it was more that I didn't trust harbor freights Chinese quality control to have a pair of them that were perfectly calibrated to one another
Offline trek97
« Reply #27 on: Sep 02, 2017, 21:30:10 »
Even w my purpose built gauges.  When Im done setting.  I swap the gauges on the carbs to see if there is a discrepancy twixed the gauges.
Offline Hurco550
« Reply #28 on: Sep 07, 2017, 21:02:13 »
New tires mounted and rolled out for some quick pics. Next up, changing out the seat.
Offline trek97
« Reply #29 on: Sep 07, 2017, 21:08:00 »
The difference you have made in her is already stunning.
