Author Topic: Building my own frame  (Read 1144 times)
Offline ChopperCharles
    • Modified Motorcycles by Chopper Charles
« on: Aug 16, 2017, 11:23:39 »
I can weld, I can build a jig. I want to build a bike with a pretty wild engine, and I'm thinking I can either start with a frame from another bike, (sourced off of eBay) or I can build a frame from scratch and use a headstock from a frame I already have a title for. If I start with a frame from another bike, I'll have to do extensive modification anyhow. I will likely have to buy a tube bender either way, and make a jig either way. Although for an existing frame, the jig is likely to be simpler. Thoughts?
Charles.
Offline SONIC.
Re: Building my own frame
« Reply #1 on: Aug 16, 2017, 12:34:54 »
A pretty wild engine means powerful?
My question is how is your welding skill? And be honest because it's your life and the person you eventually sell it to's life on the line!
A pretty weld is not necessarily a good weld.
If you're confident in your welding then I say go for it.
If not, start with another frame that has the critical welds done already and modify to suit.
Or build from scratch just tacking it together, and then take it to a certified welder to be finish welded. Just make sure your joints are good hah!
« Reply #2 on: Aug 16, 2017, 13:12:38 »
Actually, not all that powerful. 50-60 hp at most. It's just very... nonstandard. Don't really want to leak it until I've at least got the basic drivetrain accomplished.
Charles.
Offline Popeye SXM
  • Also used for MX
« Reply #3 on: Aug 16, 2017, 14:33:56 »
You can get jig kits off ebay for about $300, you just have to supply the box section. If you can work out a design that has the strength and shape you want then start from scratch. There will be some lathe work required, ie head stock, swing arm mounts. Modifying a frame is easier.
Offline Tim
  • Administrator
    • DO THE TON
« Reply #4 on: Aug 16, 2017, 15:07:20 »
You can get nice jig bits here
https://www.chopsource.com
Offline hillsy
« Reply #5 on: Aug 16, 2017, 20:54:29 »
If you are not a member already, join up over here:
http://www.thechopperunderground.com
Then peruse the builds / archives. There is a stack of info on frame building (what tubing to use, which welder, how to gusset, etc).
Yes it's chopper based, but the basic construction principles apply to other frames as well.
Offline TheCoffeeGuy
  • Books, Books, Books, knowledge is within
    • The Coffee Guy's Blog
« Reply #6 on: Aug 16, 2017, 22:23:41 »
and if you are in Canada you will need a 17 digit VIN to register it for the road.   if you a joe schmo......pray for insurance.
www.thecoffeeguy.ca Not your ordinary Blog site.
1968 Harley Aermacchi ML 125 Rapido, restored
1972 Honda Cl 450 engine rebuild, a day rider soon, now sold
1980 Suzuki GS850GL Street Brat  My other day bike
2000 Harley 1200 Sport S My day bike
1982 Honda CB650 Chopper light
Offline farmer92
« Reply #7 on: Aug 16, 2017, 23:40:47 »
It varies by province
In quebec, 35$ gets you a new vin on any frame that doesn't have one.
If it is to be road plated, you must then have it inspected by one of the saaq engineers.
If it passes it is considered to be the same category as if you purchased a parts frame from a dealer.
« Last Edit: Aug 17, 2017, 07:50:09 by farmer92 »
Offline tech54K
« Reply #8 on: Oct 18, 2017, 10:58:55 »
That link is a gold mine!
