Author Topic: Ton up SR250 - a cafe racer by the numbers: 100mph, 100kg, 30hp  (Read 45764 times)
Offline Jimbonaut
    • Lost Apostle
Re: Ton up SR250 - a cafe racer by the numbers: 100mph, 100kg, 30hp
« Reply #360 on: Aug 01, 2019, 10:37:53 »
Wish I knew about that thing when I hammered out the dent in my cb tank.  Man that worked a charm, nicely done
Offline Rider52
« Reply #361 on: Aug 01, 2019, 15:37:48 »
Nice job on pulling the dent. I've seen those tools, but never used one.
Member
AMA, VJMC, AMCA
Projects
74 Yamaha TX650
3 Harleys in constant state of sorrow and a Buell
1978 Yamaha Chappy 80 burning up the highway
Cut my motor in half Sportster to Shortster
Rodekilt Revitalization 1977 Honda CB750 http://www.dotheton.com/forum/index.php?topic=76749.new#new
Offline wozza
« Reply #362 on: Aug 01, 2019, 21:02:36 »
I
The hardest thing was getting the hot melt glue off afterwards without damaging the paint.  I used a plastic 'spudger' from Ifixit (from my Mac repairing days).  It was brilliant - a hard and stiff enough plastic that you can scrape with, but soft enough not to gouge the paint.
isopropyl alcohol will help with clean up and removal....Your lucky(or more skilful ;) )  as the few tanks I tried on failed due to the thickness of the metal and the small size of the dents....
Offline Rat_ranger
« Reply #363 on: Aug 02, 2019, 02:50:33 »
I had some large shallow dents in my dt400 tank.  I used a tool just like that from harbor freight.  It did a surprisingly good job.  It did take some paint and decals off, but I was stripping it anyway.
Offline zap2504
« Reply #364 on: Aug 02, 2019, 18:10:58 »
I originally had one of those "bridge" pullers too. Saw the video results of the "slide hammer" tool and got one of those instead (why I recommended it a while back). Better control over force applied, not limited to what structure the "bridge" rests on, etc.
Yes, a plastic body putty spreading tool can also be used (with rubbing/isopropyl alcohol) to remove dried glue. In the video I saw they used a plastic "razor blade" with great effect too.
Offline pidjones
« Reply #365 on: Aug 02, 2019, 18:39:43 »
I bought some of the plastic razor blades from West Marine. They are used for removing stickers, labels, stripes, etc.
Offline JadusMotorcycleParts
    • Jadus Motorcycle Parts
« Reply #366 on: Aug 04, 2019, 10:44:06 »
Gotta get me some plastic razor blades then!  Genius!
Zap the slide hammer was in another price category but I understand the use and it would come in handy for future projects no doubt.
Offline doc_rot
« Reply #367 on: Aug 05, 2019, 02:57:22 »
Majority of sport bike axles are much larger diameter. I'm guessing the SR250 has 17mm front axle and 20mm rear? Could probably find a swing arm pivot bolt to fit but it would need cutting and threading. I think Suzuki used 17mm 'gun drilled' on early GSX-R? Not too familiar with other brands so couldn't make a recommendation
Yeah GSXR750  20mm rear 17 or 15mm  front depending on year. Easily adaptable. cheap. The factory axles are swaged where the threads are so they are extra thin and light and use a smaller nut.
Just out of curiosity how much was it to EDM those axles?
« Last Edit: Aug 05, 2019, 02:59:02 by doc_rot »
« Reply #368 on: Aug 09, 2019, 03:39:02 »
It cost an arm and a leg!  50 and 60 Euro respectively.  To have custom ones machined would have been much more and to modify something else would also have cost a bit - considering I would not have been able to do the work myself.
« Reply #369 on: Aug 09, 2019, 03:50:58 »
Found some time this week to start rebuilding the forks!  Geeze these ones were shot.  I was not expecting to need to order new holding clips (completely rusted out).  New seals and dust seals I already have.  These, along with the fork emulators, new oil, trimmed springs and the pre-load adjusters I have designed will get installed.  The fork legs will also get shaved - to remove the fender mount brackets (will mount the fender on the fork brace) and blasted.  The seals were stubborn as hell to get out but with force and heat they came.
Of course I weighed them too - for a before and after.  I presume there will be at lease a 100g weight reduction each side here too.
The stanchions have a bit of pitting in them, but it is nowhere near the working/sealing surfaces.  So I will polish them up and fill them with epoxy.  But the most important thing is they were both straight!  And the hard chrome surface down by the damper rods was also ok.
