Its because of the finer increments of 1/1000 inch than 1/100mm i think, but what do i know, im a welder! those measurements are too fine for me..
1/1000" = .001"1/100mm = 0.000393701"Which is finer?
0.035 - 0.055mm. Is this good?
Did you bother to read what i wrote?
I had to read? WTF is this?
Yepp, Special Piston Services came back with a recommended spec: 'CLEARANCE = .0032” @ 23 MM BELOW OIL CONTROL RING you could perhaps try slightly less maybe .0025 min'Anyone know why an Australian guy/company uses inches for bore measurement? Then mm for measurement position? .0032” = .08128mm, .0025" = 0.0635mm
if australia is anything like I learned from mad max …
Mad Max is actually a documentary!Crazy
I've had another good long thought on the subject... It really depends on the bore and material of your piston. Is the new one forged as well or is it cast? If it's forged, you definitely have to go up with the tolerances and gutt-feeling tells me, around the 0.07mm to 0.08mm clearance is roughly 1/100 of the bore or one percent differential expansion due to dissimilar materials of piston and cylinder/liner in the hottest area of the piston and should be alright for a forged piston. If it actually is a cast piston, going below one percent will prolong piston life dramatically and aiming for the higher end of the range will probably just do you fine. Maybe being a bit more gentle on the first hundred kilometres might be advisable anyhow.Cheers,Greg
