Author Topic: Valve cover leaking from bolt.  (Read 1488 times)
Offline mada1594
« on: Aug 22, 2017, 19:51:08 »
Hi guys I am new to motorcycles and working on them. I just got my first bike it is a 1975 cb200t. I am having a problem with oil leaking from the bolts in the valve cover.
I realized there were no crush washers so I put those on there and it helped stop the leak from all the bolts except one. The bolt on the right back closest to you is still leaking from the top of the bolt. Now I did notice that the nuts on the left side when tightened go further down the bolts than the ones on the right. The nuts on the right side when tightened barely sit flush with the bolt.
The leak is not coming from the gasket it is seeping out from the top of the bolt. Like I said I am new to this so please help with any tips and ideas on how to fix this thanks!
Offline VonYinzer
Re: Valve cover leaking from bolt.
« Reply #1 on: Aug 22, 2017, 20:36:25 »
Pull the valve cover, ensure the gasket is ok and re-torque the cover back down according to factory specs.
Online Tim
  • Administrator
    • DO THE TON
« Reply #2 on: Aug 22, 2017, 20:38:20 »
There may be a locating dowel missing.  Typically valve cover bolts don't need to seal - they pass through sections of the cover that are surrounded by mating surfaces.  One might not be, but should perhaps pass through a locating dowel.
Parts diagram?  Always start with the manuals.
Offline VonYinzer
« Reply #3 on: Aug 22, 2017, 20:47:22 »
That ^^^
Pics may help as well
Offline mada1594
« Reply #4 on: Aug 23, 2017, 02:12:16 »
Ok thanks for the tips I will try that! Also I realized that the previous owner installed regular nuts on it and not "cap nuts" that originally came on the bike could this also be the reason the oil is running up through the bolt threads and seeping out the top between the bolt and nut?
Online Tim
  • Administrator
    • DO THE TON
« Reply #5 on: Aug 23, 2017, 08:44:54 »
Looks like we found the manual a bit ago (uploaded 2011).  It's 17MB in size and is the original Honda Service Manual.
www.dotheton.com/downloads/Honda_CB200_CL200_Manual.pdf
Offline teazer
« Reply #6 on: Aug 23, 2017, 10:57:22 »
Oil feed to the top end goes up around the rear outer studs.  Cap nuts (dome nuts) and crush washers are essential.
Online Tim
  • Administrator
    • DO THE TON
« Reply #7 on: Aug 23, 2017, 11:10:59 »
No mention of washers in the manual.  Just 'cap nuts' torqued to 13-16 lb ft.  They include the bolt in the tightening pattern as #9 but I wouldn't go past 6-7 lb ft on it.  I'm guessing it's a 6mm bolt threaded into aluminum.  The nuts go on studs so the higher torque is fine.
Cap nuts and some copper washers for good measure should seal it up.
Offline mada1594
« Reply #8 on: Aug 23, 2017, 11:46:48 »
Ok great thanks for the help guys! Ordered the cap nuts and some more crush washers to try this again I will update in a few days if the problem was solved.
Offline mada1594
« Reply #9 on: Aug 23, 2017, 11:53:33 »
Also I don't have a torque wrench that shows lbs of pressure is there any way to do it without one or do I need to buy one bc idk what 16 lbs ft Feels like.
