Author Topic: CB750 No Plunger Hellride Freedom Machine  (Read 42935 times)
Offline WhyNot
Re: CB750 No Plunger Hellride
« Reply #290 on: Aug 04, 2018, 08:05:08 »
good job
1975 CB750K5
1974 CB350F
Offline trek97
« Reply #291 on: Aug 04, 2018, 14:02:51 »
a good place to hide your stash in there
Offline irk miller
« Reply #292 on: Aug 07, 2018, 23:42:00 »
Instead of a big reservoir...
Offline Hurco550
« Reply #293 on: Aug 07, 2018, 23:44:05 »
#itsaracebikenow
~ bradj
Offline doc_rot
« Reply #294 on: Aug 14, 2018, 21:57:19 »
I watched my boss lock up his rear wheel because of a tube setup like that. If the brake fluid gets hot and expands, there is no where for it to go other than to pressurize the system and push the caliper piston out which makes it drag which makes it hotter so you get a positive feedback loop, until lock. Or as the pad wears the pistons retract too far because more fluid cant be pulled into the system because of the vacuum.  Thats why the caps of reservoirs have those funky rubber inserts to expand and contract with the system.
Offline irk miller
« Reply #295 on: Aug 14, 2018, 22:19:16 »
Hmm.  I wonder if I can come up with enough of a loop or extra space or something else.  I could go 3X, 5x or 10x on length maybe.  I'm mainly trying to avoid hanging a huge reservoir somewhere on the frame.   One option I considered is hanging the reservoir somewhere under the seat where it's visible, but not in such a profound space.  Having the M/C is a lot of visual clutter, since it seems like most vintage choppers run a drum.
Offline stroker crazy
  • crazy as a fox
« Reply #296 on: Aug 14, 2018, 22:54:47 »
Maybe you could use a section of flexible rubber tubing ...
Crazy
“Ride like the Wind” W.H.
Offline irk miller
« Reply #297 on: Aug 15, 2018, 00:10:40 »
This is the other setup I was referring to. I could always go with a more fashionable reservoir, and one that’s smaller.
Offline doc_rot
« Reply #298 on: Aug 15, 2018, 01:41:49 »
What about a cable actuated Master cylinder? then you would have more options for placement.
« Last Edit: Aug 15, 2018, 01:47:19 by doc_rot »
Offline doc_rot
« Reply #299 on: Aug 15, 2018, 01:48:43 »
or how about a Master cylinder with an incorporated reservoir?,  you could probably repurpose what you have into something like this. and mount it low on your frame to clean the "triangle" thing up.
https://www.performancemachine.com/motorcycle-hand-and-foot-controls/rear-master-cylinders.aspx
« Last Edit: Aug 15, 2018, 04:01:10 by doc_rot »
