Author Topic: DT250 Tracker  (Read 6085 times)
Offline JadusMotorcycleParts
    • Jadus Motorcycle Parts
Re: DT250 Tracker
« Reply #30 on: Jul 30, 2018, 05:00:46 »
'It's an expensive process building wheels, the spokes and rims are not cheap! Very happy with the end result though.'
But oh so worth it!  Looking great man.
Interesting about the feedback on shocks too, will be considering this with my current build.
Offline Mr Bernzo
Re: DT250 Tracker
« Reply #31 on: Jul 30, 2018, 05:17:37 »
Thanks Jadus, I think I will follow dernanno's advice with the YSS shocks. I am planning to visit a local suspension shop that sells both before making my decision though. Either way they will be sprung to match bike and rider weight.
Will be a month or so before I get around to shocks though.
Sent from my Moto G Play using Tapatalk
Smell that? 2 stroke...
1978 Suzuki GT185, 2012 Husky TE449, 2003 Suzuki SV1000
Offline Mr Bernzo
Re: DT250 Tracker
« Reply #32 on: Aug 08, 2018, 10:06:20 »
Still haven't quite got the electrical sorted so I thought I would jump onto the suspension while I am at it.
The rear shocks have pitted shafts and not worth the rebuild. They measured 305mm eye to eye which seems shorter than standard, I thought 320mm was correct length?
After much research, I ordered 330mm YSS gas charged with springs to suit 80kg rider.
The front end is off a 1990 dt200, one fork leg is appart and looks in good condition. Ordered springs, seals and emulator valves. Will also make spacers to reduce stroke length by 50mm.
Hopefully all of this will arrive early next week!
Sent from my GT-N8000 using Tapatalk
Offline Mr Bernzo
Re: DT250 Tracker
« Reply #33 on: Aug 09, 2018, 03:14:04 »
YSS shocks arrived today, built and delivered in only 2 days. Springs, seals and emulators for the front end as well.
Great service.
Offline JustinLonghorn
Re: DT250 Tracker
« Reply #34 on: Aug 09, 2018, 08:49:34 »
Righteous
Into The Sunset, CB750 build
TT500 the Animal
Offline 1fasgsxr
Re: DT250 Tracker
« Reply #35 on: Aug 09, 2018, 13:31:22 »
Nice looking stuff!
Offline Mr Bernzo
Re: DT250 Tracker
« Reply #36 on: Aug 10, 2018, 05:42:14 »
Rears are on. Going to put the front back together shortly with the new springs and valves......
It is getting close to ridable.
Offline 1fasgsxr
Re: DT250 Tracker
« Reply #37 on: Aug 10, 2018, 13:17:27 »
Which model shock did you go with? I see they have several different ones available.
Offline Mr Bernzo
Re: DT250 Tracker
« Reply #38 on: Aug 19, 2018, 10:32:02 »
I went for the basic gas charged shocks. They have some valving adjustment and threaded preload. Cost $400.
Offline Mr Bernzo
Re: DT250 Tracker
« Reply #39 on: Aug 19, 2018, 10:34:48 »
Forks are starting to come together. These are dt200 forks. New springs and emulators. Stroke length shortened by 30mm.
Looking forward to testing them out.
