Author Topic: CB450 Tracker  (Read 25698 times)
Online Pete12
Re: CB450 Tracker
« Reply #50 on: Nov 29, 2017, 09:36:37 »
Nice welds, I like using the oxy/fuel rig for stuff like this. I like where this project is heading.
Thanks very much for the comment. I have tig which I use for most things but have always used the O/A set for pipes. Very easy to control and direct the weld puddle. Someday I'll make a little speed controlled chuck so I can get a continuous weld around the butt joins.
Rolled up the cones around a length of pipe in the vice and welded the seams.
https://i.imgur.com/YaWVSBo.jpg[/img]]
Welded the reverse cone onto the megaphone and then tacked it onto the pipe.
https://i.imgur.com/F7XbXWR.jpg[/img]]
It's only tacked at this stage as it is on the mock-up bike with the rear end on the actual bike a bit different. As the actual bike doesn't have a head on it at this stage I will wait until its final assembly stage to finish welding the pipe completely. I'll also run a second pass around the join between the megaphone and the reverse cone and dress it back for a seamless finish. I will wait to install the baffle until I can actually run the bike with different baffles to see which type performs (and sounds) the best.
The exhaust looks a little out of place on the mock-up bike but I think once it's all finished and painted it will look OK. Next project, the fuel tank...
Offline Aussie Steve
  • As useful as an ashtray on a motorcycle!
Re: CB450 Tracker
« Reply #51 on: Nov 29, 2017, 11:09:52 »
This is really very interesting. If you ever feel the urge to post a video on YouTube about your exhaust making technique, I'd watch for sure. No doubt a lot could be learnt. Keep up the nice work.
Sent from my Lenovo A6020a40 using DO THE TON mobile app
Bruce comes home from the pub and sees Sheila watching Gordon Ramsay's F%*#ing cooking show on the telly.
Bruce says; "What are you watching that shit for? You can't cook to save your life!."
To which Sheila replies; "So what? You watch porn movies, donít you?"
Online Pete12
Re: CB450 Tracker
« Reply #52 on: Nov 30, 2017, 00:41:46 »
Thanks Steve. What are you interested in particularly? Megaphone design, pattern development, material selection, shape forming or welding? Not too sure about a YouTube video but happy to share some advice, for what it's worth.
Offline jag767
    • Kinesis Moto
Re: CB450 Tracker
« Reply #53 on: Nov 30, 2017, 07:14:36 »
That's very impressive. I'll be interested to see your process doing that as well.
Online Pete12
Re: CB450 Tracker
« Reply #54 on: Dec 01, 2017, 00:41:26 »
Thanks Jag, haven't seen anything from Steve yet so not really sure what you want to see. No problem with any of it, I just don't want to tell you things you already know...
Sat the head on the good bike today to see how the exhaust fitted up and it clashes with the rear caliper hydraulic hose - good thing I only tacked it together.
https://i.imgur.com/ScPYIHc.jpg[/img]]
Also put the seat on off my race bike so that I can get started on building the tank. The seat has to come down about 25mm which will happen when I make up the new rear loop. This will put the seat height at just over 800mm from the ground, which should be a good height. I'm going to buy a seat, as the Knight shape is quite complex and not so easy to make from scratch out of aluminium, and they are not expensive.
https://i.imgur.com/wpJxgA9.jpg[/img]]
I also took the rear right hand cam bearing off my spare head and put it on the front right hand side of the new motor so I don't have that ugly obsolete tacho drive sitting there.
https://i.imgur.com/CJIVwx7.jpg[/img]]
Getting closer now, I'll be happy once I've got the tank made and positioned correctly. I can then make the seat loop, battery tray and front mudguard.
Online Pete12
Re: CB450 Tracker
« Reply #55 on: Dec 06, 2017, 00:08:54 »
I bought some cardboard to get started on the tank template but before I started I sat the old tank on to see how it would go lengthwise with regards to the seat position. Funnily enough, the original didn't look too bad on there...
https://i.imgur.com/LVshn1Z.jpg[/img]]
It looked a little too wide so I decided to narrow it up by 25mm. Firstly, I cut the filler cap out with a holesaw.
https://i.imgur.com/28K3El0.jpg[/img]]
I then cut a 25mm strip out of the centre and then cut the flanges off all the way around, so the tank is now in four pieces.
https://i.imgur.com/bDjf6jK.jpg[/img]]
The next thing will be to knock all the dents out, (and there are many of them :(), then make a new tunnel and weld it all back together again. Once that's done I can make the new rear loop then align the tank and seat properly before finalising the tank mounts.
I taped the tank back together and these are before and after photos.
https://i.imgur.com/808Fw6J.jpg[/img]]
https://i.imgur.com/iTFH82L.jpg[/img]]
I sort of like the idea of using the original tank as it will retain some of the bike's character. If it doesn't look good when it's all fitted up then I will just revert to plan A, and make a new tank.
Offline SONIC.
Re: CB450 Tracker
« Reply #56 on: Dec 06, 2017, 09:40:07 »
I like it.
I think I'd take it down another inch or so in width and it will be killer.
Offline Luugo86
  • '73 CB350, '78 XS650 Cafe Killer
    • ToadStool Cycle Co.
Re: CB450 Tracker
« Reply #57 on: Dec 06, 2017, 16:48:26 »
I like it.
 +1
  Also, is the tailpiece a unit that you ordered up or fabricated? I like it.
Live to Die, Die to Live
Online Pete12
Re: CB450 Tracker
« Reply #58 on: Dec 07, 2017, 01:52:13 »
+1
I like it.
Thanks for the feedback guys. I can't really narrow it any more at the back as it is now the correct width for the seat, which is important in my opinion. I'm also struggling to get the fuel tap in to clear the carbs, but I should be able to find a way around that. I will, however, narrow it up more at the front which I believe will still have the desired effect. I'll finish knocking all the dents out then tack it together and see how it looks.
Luugo86 - the seat is a Knight type off my race bike and I'm just using it for the mock-up but will be getting one the same for this bike. Depending on where you live you can buy them in England or the States, possibly Europe as well.
Online Pete12
Re: CB450 Tracker
« Reply #59 on: Dec 12, 2017, 06:37:56 »
I ended up cutting nearly 40mm out of the tank and I think it looks OK. I tried overlapping it a bit more to see how it looked but it was starting to get a little skinny for the height so I've gone with what I had. I knocked all the dents out and then welded the seam together and will make the tunnel next and then weld that in. I can then position it correctly and make the front and rear mounts. It's certainly recognisable as a CB450 tank, just looks like it has been on a diet, which is pretty much the look I was aiming for. It matches the seat where they meet, so once the two are lined up correctly height wise they should both look like they are meant to be there. We haven't decided on a colour yet, but my brother is pretty keen to use the original striping design, carried through to the seat tail. Sounds OK to me..
https://i.imgur.com/OQ5Z8tw.jpg[/img]]
I'm undecided at this stage whether to buy a pop-up cap or just make a regular screw-on cap, but no hurry with that at this stage.
The manifold that was supplied with the new Mikuni carbs is a universal type and doesn't match up to the head too well,
https://i.imgur.com/3u7hqUq.jpg[/img]]
so I milled up a transition piece that matches both sides.
https://i.imgur.com/OxkWEaM.jpg[/img]]
https://i.imgur.com/MzNko8n.jpg[/img]]
I think it looks better aesthetically, and it will also give fuel tap a little more clearance, so I'm pretty happy with that. The increased inlet tract length may even give it a bit more low down torque which will be a good result if that is the case.
