Author Topic: Hi everyone  (Read 1782 times)
Offline 2b
Re: Hi everyone
« Reply #10 on: Oct 26, 2017, 04:02:02 »
If you do start adjusting the carb take a look in here...
https://docs.google.com/spreadsheets/d/1USvziYIyzfyxfZA1YYpQf9eP4djb0GLWbvWcmME88Gk/edit#gid=1
Cheers
Richard
He's obsessed with order and clarity. He doesn't like mess.
Harold Pinter
Build thread: http://www.dotheton.com/forum/index.php?topic=61167.msg694438#msg694438
Offline r4g5
Re: Hi everyone
« Reply #11 on: Oct 26, 2017, 10:00:54 »
Also be careful that any carb adjustment isn't disguising some other issue...check out what crazy said. I know mine was a bit off cos I put a pod on it but waiting to rejet till I get the CDI and exhaust sorted
Sent from my ONEPLUS A5000 using DO THE TON mobile app
Offline norn
Re: Hi everyone
« Reply #12 on: Oct 26, 2017, 12:37:36 »
Thanks for all the tips guys, you've given me some great stuff to work through. I'll update you all on Monday, weather permitting.
Offline Sneikz
Re: Hi everyone
« Reply #13 on: Nov 07, 2017, 01:00:00 »
For my 2 cents worth, have you drained the tank. Sounds like fuel starvation and rest period allow carbie and fuel line to fill. I'd check the in-tank filter. A quick and easy check. It doesn't take much to starve an engine and given it appears to continue slightly under choke, this may be the problem. I'd remove the tank and decant from the filler via old stocking and flush.
The Silver Bullet Thread: http://www.dotheton.com/forum/index.php?topic=71205.0
Silver Bullet Pics: https://goo.gl/photos/EXyfM3K42BHp2D6w9
Aces on the net: https://goo.gl/c8QmjP
Silver Bullet mods booklet: https://goo.gl/97mGRI
Other Bikes:
2012 Suzuki Boulevard M109R
2005 Tomos Revival (TS)
Live long and ride hard \\ //
Offline orrible-64
Re: Hi everyone
« Reply #14 on: Nov 14, 2017, 06:39:55 »
Sounds like a fuel issue. Still check what ignition module it has. Ok racing have a rev limiter. That would stop motor but you would be able to restart.  My first ace used to stall on a long ride due to sticking valves. This went away as it wore in
Offline orrible-64
Re: Hi everyone
« Reply #15 on: Nov 15, 2017, 20:44:33 »
Needle and seat check too ( carby inlet valve)
