Author Topic: Am I the Pontius Pilate of this CX500?  (Read 21833 times)
Offline Odontologist
  • Umina Beach, Australia....Where does that part go?
Re: Am I the Pontius Pilate of this CX500?
« Reply #170 on: Feb 04, 2019, 02:41:54 »
Rear section wiring of lights and indicators wrapped up and connected.
Front control and indicator wires fed through bars. Odometer/tacho and warning and indicator light wires out through bottom of upper triple in 2 bundles.
Making a bracket for my 2 gauges (Water temp and Oil press) out of some 3mm aluminium (or is it aluminum?) sheet.
Big holes are 50mm and fit on forks between clip on brackets and upper triple. Houses 2 gauges, a fan temp over-ride switch for electric fan, and choke.
Below it will be a n aluminium box welded on to bracket, with space and entry and exit ports for connectors and wires bundles. Choke cable goes through it.
Assembled, but yet to be welded, sanded and painted.
1982 Honda CX500 Roadster build
« Reply #171 on: Apr 07, 2019, 05:18:15 »
Spent all morning practicing TIG welding spare stainless scrap pipe. Decided things were not going to get much better, so took a punt and made some tack welds on headers /connecting fitting, and mufflers after setting everything on bike where I wanted them.
Not very pretty but TIG welding is hard enough without having to get down on the floor to weld on site.
Purging pipe assembly with welding gas.
Managed to weld 4 joints without burning a hole in any of them.....Success!
Everything fitted...Bonus!
Offline Pete12
« Reply #172 on: Apr 07, 2019, 06:33:05 »
Wow, nice work, and the mufflers line up with the frame loop, good job.
« Reply #173 on: Apr 07, 2019, 08:12:53 »
Cheers. Bit of luck with the angle.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #174 on: Apr 07, 2019, 15:13:41 »
Looking good.
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline crazypj
« Reply #175 on: Apr 09, 2019, 19:13:23 »
Luck or not, pipes lining up with frame does look good.  8)
Best thing I ever overheard
Brian Morgan, 1982
« Reply #176 on: Apr 10, 2019, 01:20:52 »
Thanks Man!
« Reply #177 on: Apr 10, 2019, 01:21:53 »
dead right!
« Reply #178 on: Apr 22, 2019, 08:46:32 »
Was going to have an aluminium water bottle for overflow, but changed my mind and decided to replace the original specimen bottle. Had to pull engine out....
....and while I was there, I replaced the pulser cover gasket after a youtuber commented that the one I had placed did not have the slot for the breather vent.
Now it does. Engine back on.
« Reply #179 on: Apr 22, 2019, 08:50:56 »
Had some Halcyon 830 mirrors on the Triumph, which I removed when I sold it. I really want to fit them on the CX500 but...
...they are designed to be fitted inside the handle bar via the usual bar end arrangement. I have some turn signals inside the bar end so I can't fit the mirrors in the conventional way. I decided to make a bracket to mount them on the bars from a 20mm block of aluminium.....
A 10mm threaded hole to mount the mirror...
...and 2 x M4 threded holes with a slit to tighten around bar.
Mounted on my spare handlebar and everything works. I like these mirrors. Just need to fill in small voids, finish sanding, and paint black to match everything else.
