Quantcast
Author Topic: CB550 Cylinder number 3 not firing  (Read 688 times)
Offline bergers
« on: Nov 07, 2017, 17:04:47 »
Hey everyone, I've been working on my bike on and off for the past year and have replaced a lot of parts and checked over stuff while going through it. The list is as follows:
NEW
carb kit for all 4 (floats, float valves, jets, seals, o-rings, etc.)
fuel lines
coils
spark plugs/wires
battery
CHECKED
carbs hydrodipped and cleaned thoroughly
bench synced(used something like an eighth inch drill bit under the slides and brought them to all the same height)
intake/exh valve lash
compression (bike cold, between 125 and 140psi for all 4)
point gap
spark(ok/strong on all 4)
I ran the bike off of a small temporary tank, it starts fairly easily with a shot of starting fluid, once warm it starts without it. The problem is cylinder number 3 is dead cold, I can put my hand the exhaust header at the head for number 3 while If I did for the others I would get a nice 2nd degree burn. A bike needs 4 things to run; compression, air, fuel, and spark. I know I have spark, I have compression and air, so I assume at this point it's some elusive fuel issue. All bowls have fuel(some overflow periodically), so I'm not sure if it's a float height issue or a carb body needs to be replaced. Any help is appreciated
« Last Edit: Nov 07, 2017, 18:01:36 by bergers »
Offline coyote13
Re: CB550 Cylinder number 3 not firing
« Reply #1 on: Nov 07, 2017, 17:30:25 »
Is there an accelerator pump on #3?  If there is, might check that the diaphragm doesn't have any tears or pinholes and isn't pinched.  Also make sure the slide is synched correctly with the other three carbs, I had a lock nut that kept backing off on my CB750 and chased my tail on it for quite some time before I realized the slide was wide open all the time
Half the fun's in the get there...
Offline bergers
« Reply #2 on: Nov 07, 2017, 18:13:47 »
Nah its a 74 550, so no diaphragm. And I corrected the original post, I meant to say I synced all of the slides to each other with the drill bit, not the butterflies.  I would think that should at least put me in the ballpark of having them synced.
Offline cxman
« Reply #3 on: Nov 07, 2017, 19:00:58 »
squirt a bit of starting fluid in #3 carb when the bike is running
does it pick up? if it does then you know the slow jet circuit or ? sync? is whacky
if it does not swap the plug with another cylinder or a new one restart
1978 CX650 Super Deluxe
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1974 kawasaki 350 bighorn
1983 GL1100 aspy full dress
1983 GL1100 Nekid
and a bunch of others
Offline bergers
« Reply #4 on: Nov 07, 2017, 19:41:41 »
That's a good idea, I'll try to do that tomorrow if it's not raining.
Offline coyote13
« Reply #5 on: Nov 08, 2017, 16:30:33 »
Suppose it could also be carb -> head vacuum issue.  Check to make sure that carb is fitted properly in the insulator boot and that the boot doesn't have any cracks.
