Author Topic: 1974 CB360 - first bike/build  (Read 15446 times)
Offline huck_finn
    • 1974 CB360
Re: 1974 CB360 - first bike/build
« Reply #140 on: Jul 19, 2018, 14:38:51 »
My original plan was to use the hump design from my seat to build a custom piece for my running/brake light and turn signals. But I am going to have to do some more measuring to make sure I won't have any wheel clearance issues. I found the tail light after seeing Derek Kimes XJ750 on BikeExif. http://www.bikeexif.com/turbocharged-yamaha-xj750-maxim-restomod
Morimoto Mod Pod, dual intensity: https://www.theretrofitsource.com/morimoto-mod-pod-led-lights.html
I found these lights on Amazon for my turn signals: https://www.amazon.com/gp/product/B01ADHUWWA/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Offline huck_finn
    • 1974 CB360
« Reply #141 on: Jul 26, 2018, 11:22:23 »
Lots of sanding, a few more layers of fiberglass, and lots more sanding...hours. I went through about 10 paint brushes, lots of plastic cups (some of which melted on contact with the resin...sending me back to find some more durable ones).
I burned through to the fiber a few times when sanding. I wasn't 100% sure if just another layer of resin would hold up, so just to be safe I added another layer of fiber/resin. There are also some areas where the cloth version developed air pockets. But I cut/sanded those back down and built up the areas with chop. The spots still show up in the photo, but there isn't any air in there.
I think I am ready to put a thin coat of bondo on it to even everything out.
Offline huck_finn
    • 1974 CB360
« Reply #142 on: Jul 26, 2018, 11:26:05 »
I am going to raise the front lip of the pan to keep the bottom line of the pan lined up with the bottom line of the tank.
I did end up trimming off about two inches from the rear of the frame, but arch across the frame rails for the rear fender is still in place. I cut the frame and left the ends flat, but I may need to come back and trim it up at an angle so my tail/turn piece will fit without too many problems.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #143 on: Jul 26, 2018, 11:28:26 »
Tail looks good. Another layer of fiber won't hurt anything, that's the right way to go IMO.
'78 Honda z50 - http://www.dotheton.com/forum/index.php?topic=76059.0
Offline Sderbyshire
  • Into Sailing, classic Triumph cars and motorbikes.
« Reply #144 on: Jul 26, 2018, 12:40:11 »
Thatíll look great, make sure the tank rear is in the rubber holder not on it when you measure !
Steve
Offline huck_finn
    • 1974 CB360
« Reply #145 on: Jul 26, 2018, 15:13:39 »
I forgot to mention that I am going to tape the seat back up and make a fiberglass pan for the cushion/upholstery to sit on based on the seat's current shape. I am having trouble deciding if I want to glass in some bolts to the pan that will pass through the seat body (?) that sits on the bike, and use some type of nut to tighten everything down...or if I want to put some rivet nuts in the pan and and tighten everything down using some cap head bolts from underneath.
Any suggestions?
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #146 on: Jul 26, 2018, 15:45:49 »
Any suggestions?
For the tail on Luna...I used some of those rubber plugs with threaded inserts embedded into them, drilled holes and epoxied them right into the tail. I had to replace one because it decided to spin on me, but the rest of them worked well for 4 years. I notched the rubber so it would have some teeth for the epoxy to grip. Figured it might give a bit of dampening. I ran 3 allen head bolts with flat washers and split locks and never had an issue.
They make them with studs, too.
« Last Edit: Jul 26, 2018, 15:54:19 by advCo »
Offline Oz350Four
« Reply #147 on: Aug 03, 2018, 02:19:03 »
Hey advCo what size and where did you get those stopper things...???
"Me speed officer... never..!!"
1972 Honda CB350 Four - Project Ol' Red
2007 Harley Davidson Softail Deuce - sold to start this project
Offline huck_finn
    • 1974 CB360
« Reply #148 on: Aug 31, 2018, 16:33:12 »
It was so painfully obvious that my taillight section was going to be destroyed on my first bump - so I spent a little time working out how to add my taillight to the rear hump without changing the profile too much. I 3D printed the black piece you can see through the glass to make sure I got a consistent slope.
Online Maritime
« Reply #149 on: Aug 31, 2018, 17:53:30 »
Nice job
