Quantcast
Author Topic: 73 CL 350 frame welding...  (Read 2502 times)
Offline hooligan998
« on: Nov 28, 2017, 01:01:53 »
I have the frame stripped and it's ready to go the welder soon.  My goal is to stiffen the frame to reduce flex.  I will have the welder tig up the seams, but I am also interested in adding stiffeners from the rear spine to the down tubes.  Does anyone have pics or dimensions handy or point me in the right direction on where to find this info?  The frame will not be detabbed or cut.  The bike will be staying essentially stock with a few upgrades like 18" hoops front and rear to utilize better rubber, electronic ignition for reliability, upgraded suspension for better handling and a few other mods to strengthen performance and endurance.
Thanks.
Offline TheCoffeeGuy
  • Books, Books, Books, knowledge is within
    • The Coffee Guy's Blog
Re: 73 CL 350 frame welding...
« Reply #1 on: Nov 28, 2017, 19:17:38 »
Wow.  Stock frame and its not strong enough?  REa;ly unless you are racing it with some huge oversized engine, thats a pretty stiff frame already.
JMO
www.thecoffeeguy.ca Not your ordinary Blog site.
1968 Harley Aermacchi ML 125 Rapido, restored
1972 Honda Cl 450 engine rebuild, a day rider soon, now sold
1980 Suzuki GS850GL Street Brat  My other day bike
2000 Harley 1200 Sport S My day bike
1982 Honda CB650 Chopper light
Offline Hurco550
« Reply #2 on: Nov 28, 2017, 20:06:55 »
Also, be careful welding up the gussets that are already there. The un-welded ends are there by design. The frame will flex some, its made to and those are often left un-welded by design. The frame will still try to flex like before, and those areas are designed for the movement. Welding them may result in cracked welds.
"If you want safety and sanity don't mess around with choppers to begin with and don't come crying to me for recommending something that broke down the line. You're going to be the "builder" so use your own judgment and build to you own personal levels of safety and sanity." - Chopper Handbook
Offline Rider52
« Reply #3 on: Nov 29, 2017, 01:11:16 »
Some of the vintage racers carefully grind down the big weld on the backbone and tig up the seam. They both remove and weld in small segments, the sheet metal backbone  is thin. I've seen stiffing gussets at the lower edge of the triangle under the battery box.  Here's some info on building a WERA Vintage racer http://www.eurospares.com/framemod.htm
Member
AMA, VJMC, AMCA
Projects
74 Yamaha TX650
3 Harleys in constant state of sorrow and a Buell
1978 Yamaha Chappy 80 burning up the highway
Cut my motor in half Sportster to Shortster
Rodekilt Revitalization 1977 Honda CB750 http://www.dotheton.com/forum/index.php?topic=76749.new#new
Offline Rider52
« Reply #4 on: Nov 29, 2017, 01:16:10 »
This is a race bike where I had a very tiny bit of involvement. http://www.sundialmotosports.com/hondacb350.htm
Member
AMA, VJMC, AMCA
Projects
74 Yamaha TX650
Offline hooligan998
« Reply #5 on: Nov 29, 2017, 01:19:42 »
The original plan is to just weld the seams along the parts of the frame that are stamped to increase rigidity.  I have ridden this bike up at Deals Gap and the bike tended to wallow in the turns.  I know that this is a combination of things and not just the frame, therefore my goal is to have and better handling CL when all is said and done.  I had not planned on welding up any of the gussets.  As far at stiffeners that run from the rear of the spine to the rear down tubes, it was in an article that I had read some years back about a frame prepared for racing.  There are no engine mods planned at this time, nor will there be until the bike is done and dialed in.  After that, some engine mods might be considered.
The idea is to keep it all original, even down to the goofy ass tail light, but to make it so it's more fun in the turns.
Most of my experience lies in more modern sportbikes, therefore I'd like to hear more constructive feedback on mods to make the old CL handle as best as it can.
Thanks Hurc and Rider for the feedback.
« Last Edit: Nov 29, 2017, 01:22:02 by hooligan998 »
Offline K4
« Reply #6 on: Nov 29, 2017, 21:12:31 »
Here’s an option, using a 1” square tubing.
http://www.dotheton.com/forum/index.php?topic=48453.10
Offline hooligan998
« Reply #7 on: Nov 30, 2017, 00:50:38 »
Excellent.  Thank you!
Offline hooligan998
« Reply #8 on: Nov 10, 2018, 17:45:44 »
Realized I had never posted up the work I had done on the frame.  A buddy down in NC did it up for me.  He's an old salt, Navy welder/instructor.  He's also an old biker.  This is what he did up...
Next step is to have it stripped and powder coated.
Offline The Limey
  • Evil English Villain
« Reply #9 on: Nov 25, 2018, 11:38:16 »
Is it not stiff enough as standard?  Unless you're blowing your wad on top flight Online or WP suspension and super sporty tyres, efforts to reduce frame flex are somewhat pointless.
