Author Topic: Trash to Tracker, Xl350 UPDATED!  (Read 7809 times)
Offline 2strokeTRush
Re: Trash to Tracker, Xl350
« Reply #10 on: Dec 17, 2017, 22:09:54 »
i know photo bucket has changed their settings, Now I can only see one picture as well. ANYone have a idea?
Take it from me, I'v made this mistake before.
Offline irk miller
« Reply #11 on: Dec 17, 2017, 22:22:31 »
I can see them all, because I'm using Chrome with the Chrome extension that fixes it.
Offline WhyNot
  • ~~~If it ain't raining, I'm riding~~{iii}?~~prost~
« Reply #12 on: Dec 18, 2017, 06:19:46 »
All but one.
Also using Chrome.
2015 Toyota Taco DD now
2006 Harley Davidson Heritage Softail
1975 Honda CB750K5 needs carb work
1974 Honda CB350F2 needs tins painted (being lazy)
1972 Honda CB175K2 roller no engine
1972 Honda CB/CL350 Engines need roller
1972 Honda SL350K2 Frame for above engine
1972 Honda CB100K2 needs kicker shaft
1990 Mitsubishi MM runs, but no power
1984 Dodge D50 Beater was DD since 1997
« Reply #13 on: Dec 21, 2017, 23:58:01 »
Hosting pictures on Imgur now so hopefully everyone can see them. Changed the oil in the case and I got the rebuilt carb installed as well as the header pipe with a new gasket, Adjusted the timing, fresh fuel from my auxiliary tank, with a few kicks she fired up! I couldn't believe it. Not smoking and throttle response is good. Never realized the choke cable is seized so I was using some wire to hold it shut. Anyone know where I can get one? Not having much luck online.  Motor sounds healthy soI don't think a rebuild is needed. No leaks. Decided to take it for a spin around the block and all gears in the trans are there and the clutch is working smoothly. Uploaded a short video to youtube so you guys could see it.
« Last Edit: Dec 22, 2017, 00:02:01 by 2strokeTRush »
Offline 1fasgsxr
« Reply #14 on: Dec 22, 2017, 08:32:54 »
I can see almost all of them now. Its usually my work computer that wont let me view them.
What do they expect me to do while I am here??  Work ?   ;D
« Reply #15 on: Dec 30, 2017, 10:18:59 »
Started the tear down and pulled the motor, wow what a easy job compared to the SOHC4 bikes I'm used to, tried to label the wiring harness as best as possible since I'm replacing the handle bar switches with one switch for a cleaner look.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #16 on: Dec 30, 2017, 19:18:42 »
Nice, another 350. Iím in
'78 Honda z50 - http://www.dotheton.com/forum/index.php?topic=76059.0
« Reply #17 on: Dec 31, 2017, 12:33:32 »
Thanks man, I have probably read your thread 5 times by now. Great work
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #18 on: Dec 31, 2017, 16:47:18 »
Thanks. Fun bike, tracking down an ignition issue at the moment but should have it out and about for the spring.
« Reply #19 on: Dec 31, 2017, 17:27:33 »
Yeah you got plenty of time to figure that out!  Do you have any idea of where I can pickup a choke cable? not having much luck finding one.
