Author Topic: Cleaning rust off chrome exhaust  (Read 1254 times)
Offline TranceMachineVienna
« on: Dec 11, 2017, 03:28:23 »
Hey guys!
its winter and I want to clean off light and medium surface rust off of my XS 750 chromed exhaust.
Especially the welding seams have a good amount of rust.
What would you guys use to clean it?
Read a lot about .00 steel wool and WD40 or even Coca-Cola...?
Thanks in advance!
Online XS750AU
Re: Cleaning rust off chrome exhaust
« Reply #1 on: Dec 11, 2017, 05:50:43 »
Quote
or you can use diesel instead of WD40.
“Engineering is the art of being approximately right rather than exactly wrong.”
Yamaha XS750-2D
Yamaha XS896
Husaberg FE550
Yamaha TT250
Yamaha IT200N
« Reply #2 on: Dec 11, 2017, 06:21:17 »
Thank you Tim!
Will steel wool scratch the chrome?I guess not since chrome is harder than steel...
Online XS750AU
« Reply #3 on: Dec 11, 2017, 06:45:06 »
Quote
Correct - no problem as long as you are polishing by hand.
Yamaha XS750-2D
Yamaha XS896
Husaberg FE550
Yamaha TT250
Yamaha IT200N
Offline Hurco550
« Reply #4 on: Dec 11, 2017, 11:58:23 »
I cannot speak highly enough of glass cook top cleaner and aluminum foil. Seriously, results are amazing
~ bradj
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #5 on: Dec 11, 2017, 14:01:39 »
Stainless steel kitchen sponges for the rough stuff, finer steel-wool for the nitty-gritty.
My Blog:
Offline clem
  • static fluff
« Reply #6 on: Dec 11, 2017, 14:05:17 »
Aluminum foil and water 100%. You'll forget about the rest.
Sent from my SAMSUNG-SM-G930A using DO THE TON mobile app
Offline Tim
  • Administrator
    • DO THE TON
« Reply #7 on: Dec 11, 2017, 16:21:45 »
#0000 steel wool and WD40 etc.
Offline irk miller
« Reply #8 on: Dec 11, 2017, 21:03:05 »
Coca-Cola has phosphoric acid in it, which converts rust to iron phosphate.  Same stuff we like to talk about for tank rust removal and so on.  That's why Coca-Cola is useful for rust removal or even breaking loose rusty bolts.  I like to clean rusty chrome with SOS pads first.  Then some phosphoric acid to convert the rust, then a polish with the finest steel wool as has been suggested.  Aluminum foil works nicely to cover up any rust (or black iron phosphate spots) you couldn't get rid of, since polishing with it just transfers aluminum from the foil to the rust.  Because rust expands so much, what you see before you start is typically much worse than when the rust is gone.
Offline datadavid
« Reply #9 on: Dec 12, 2017, 07:26:03 »
Get the rough stuff like that, then polish up with autosol or similar. I electropolished mine, had a machine at the workplace at the time. Brilliant results.
