Author Topic: Dirtbag Oil-Boiler  (Read 9316 times)
Offline crazypj
Re: Dirtbag Oil-Boiler
« Reply #40 on: Jul 21, 2018, 15:56:06 »
That's a better setup than the earlier screw adjuster type.  Those shims will be easy to measure and swap.   Cool!
Rumor has it that Suzuki redesigned top end on Pop's Yoshimura's request. You get an extra 500~1000 rpm with the lighter rocker and shim arrangement Had a major issue when valve lift got toň high, rocker arm hit edge of ship and spat it out. Only the 600 and 750 ever had -shims, I havent tried retro fitting to 11/1200 head but I have some parts to try. You could fit 11/1200 top end to 750 but transmission would be weak point (1100 breaks stock 5 speed, don't think 6 would last long with extra power and torque?)
1200 Bandit should have 43mm forks? I sold the set I had, they are now on a GS1100 (posted pic somewhere?) Oh, I'm pretty sure I have some 0.5mm OS pistons for 750 motor. Can't remember where I stashed them at present though? (was going to rebuild a 600 motor I have with a 750 top end on it)
« Last Edit: Jul 21, 2018, 16:04:24 by crazypj »
Best thing I ever overheard
Brian Morgan, 1982
Offline doc_rot
« Reply #41 on: Jul 21, 2018, 20:14:06 »
If i'm going to rebuild a motor for this bike its gonna be the 1100, or possibly a bandit 1200 motor.
Offline crazypj
« Reply #42 on: Jul 22, 2018, 01:38:19 »
7-11  8)
Brian Morgan, 1982
Offline doc_rot
« Reply #43 on: Aug 17, 2018, 03:14:44 »
front end sorted out. Took a bit more machining than I hoped for but it all came together. I used the bandit wheels, ebc rotors and original calipers. The rotors needed a bigger PCD, and the ID opened up to fit the bandit wheels. The calipers needed a small washer to center them on the disk, and since I was missing a wheel spacer, I decided to make them all from scratch and delete the speedo drive while I was at it.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #44 on: Aug 17, 2018, 09:23:15 »
Not sure how I missed this. Following along. One of these came up for sale locally not too long ago and I have to say I was very tempted.
Offline JustinLonghorn
« Reply #45 on: Aug 17, 2018, 09:26:16 »
I can dig it.
Into The Sunset, CB750 build
TT500 the Animal
Offline doc_rot
« Reply #46 on: Nov 03, 2018, 05:36:06 »
the frame has been boxed in and braced. The broken motor mount is repaired. This frame is a proprietary alloy that is basically 7005. I used 6061 for the braces and 5556 filler rod. The castings were difficult to weld, twice I had something in the casting explode and pop molten aluminum out at me. I want to brace the swingarm as well, but I'm going to wait till its on the road so I can do a comparison. I painted the triple trees with gun kote and installed new bearings. I went through all the bearings in the rear end and cleaned them out and packed with new grease. Its rolling again, sitting on Metzler Sportec M3, which i spooned on sweating it out on the garage floor(I'm a Luddite when it comes to tire machines). Never ridden a metzler tire before, excited to try them out. I'm still on the hunt for an engine.
« Last Edit: Nov 03, 2018, 05:44:07 by doc_rot »
Offline Luugo86
  • '73 CB350, '78 XS650 Cafe Killer
    • ToadStool Cycle Co.
« Reply #47 on: Nov 03, 2018, 17:29:14 »
Sexy welds
Live to Die, Die to Live
Offline pidjones
« Reply #48 on: Nov 03, 2018, 21:32:10 »
I know nothing about aluminum welding (very little about steel welding). But, as a GoldWing rider, welding extrusions to castings all with different alloys is a bit scary. It took Honda until 2005 (building 2006 models) to finally get theirs right.
Online canyoncarver
  • 'hacking is learning'
« Reply #49 on: Nov 04, 2018, 13:55:08 »
Really nice bracing work.  I'm glad you haven't ditched this project.
73' The Commando
YZF750/1000R The Fly
KZ 750 Twin
ZRX 1100
KZ400 The Rabbit
KLR650, 69' Norton P11 Ranger, a 65' Atlas, a 60' BSA scrambler, 93" shovelhead chop, an 86' FXR, and an F9 Bighorn
more YZF750R's, more KZ's, a Zephyr750...and the ever unfinished 75' CB550 cafe.
