Author Topic: 1998 Gsxr 750 build  (Read 10076 times)
Offline 1fasgsxr
Re: 1998 Gsxr 750 build
« Reply #50 on: Feb 13, 2018, 21:50:50 »
I got the pump assembly back in the tank tonight. And messed with the tail fitment while keeping the stock tail light and inner fender...should be fun
Offline 1fasgsxr
« Reply #51 on: Feb 25, 2018, 19:39:02 »
Got some work done , but the pump is leaking pretty bad...radiator on and all fluids in.
Offline 1fasgsxr
« Reply #52 on: Feb 25, 2018, 19:45:24 »
Something sits a little crooked. ..
Offline nateb
« Reply #53 on: Feb 25, 2018, 22:18:20 »
Hey man Iím Nate, kick ass build. I bought a Cb550 from a stoner with a 2001 gsxr1000 front end flopping around in the neck. He had big hopes but no money. Anyways Iím using the fork but I have a set of those wheels with really nice rubber on them. They are the 3 spoke polished aluminum wheels. If you could use them or know someone that could Iíd let them go cheap to get them out of here.
Offline canyoncarver
  • 'hacking is learning'
« Reply #54 on: Feb 26, 2018, 11:59:37 »
Nice progress.  Is it the tail light that's crooked or the seat?  It doesn't look too far off at least.
73' The Commando
YZF750/1000R The Fly
KZ 750 Twin
ZRX 1100
KZ400 The Rabbit
KLR650, 69' Norton P11 Ranger, a 65' Atlas, a 60' BSA scrambler, 93" shovelhead chop, an 86' FXR, and an F9 Bighorn
more YZF750R's, more KZ's, a Zephyr750...and the ever unfinished 75' CB550 cafe.
Offline 1fasgsxr
« Reply #55 on: Feb 26, 2018, 12:50:51 »
I think its the tail that sits wrong..I don't know the brand so it may not be that nice of a piece, plus I don't think it was designed to be run with the tail light either. Nate send me a pic of those wheels?
Offline teazer
« Reply #56 on: Feb 26, 2018, 13:07:59 »
Seat shell is clearly not square to that subframe - assuming the shot was actually dead on from the rear and not off to one side.  I.e. perception matters, but it looks low on the left.
The question is why.  Is it that the seat came from a mold that wasn't straight or do the mounts have some range of adjustment/slack or is the subframe less than 100% straight?  Easy place to start is to loosen the mounting screws and see if it can be tweaked straight. If not, can the mounting holes be slotted slightly to bring it back plumb? If that's still not enough, it's time to check the subframe and mounts to see how far out of square they are. No need for a CMD Computrack analysis.  Simple straight levels and or cheap laser levels are adequate to determine what's wrong.
We had an FZR400 that was dead on straight in most planes, but something didn't look right. I discovered that the wheels could not be made to be in line because the steering head was pushed 12mm to one side.
A good place to start is to get the front wheel vertical and then see if the rear wheel is also vertical AND in line with the front and if the seat mounts are dead on horizontal at the same time.  new bikes are not always spot on and old bikes are usually out of alignment in several planes.
Offline 1fasgsxr
« Reply #57 on: Feb 26, 2018, 13:13:41 »
It could be all of those things Teazer. The poor thing appears to have had a rough life. I bought the seat used off Ebay because it was cheaper than trying to go back with stock plastics. The subframe is two separate pieces, should be easy to tweak back if its off any. I'm just at the put it on and see where its at stage right now.
Offline crazypj
« Reply #58 on: Feb 26, 2018, 14:41:08 »
Common problem when bolts are overtightened. There was service bulletin about the 'problem'
Torque is crazy low, around 4~6 ft/lbs. The bolts feel like they could fall out  as it's just about finger tight (not using a socket or wrench)
Best thing I ever overheard
Brian Morgan, 1982
Offline nateb
« Reply #59 on: Feb 26, 2018, 15:04:53 »
Hey man- I couldnít post a pic in the message area of your member info so have to make it public-the rear is a Shinko Verge 190/50 zr17 95% + and the front is a Michelin Pilot 120/70 zr17 95% +.
