Quantcast
Author Topic: KZ400 oil leak - clutch push rod oil seal  (Read 574 times)
Offline saviola8
« on: Dec 25, 2017, 20:51:48 »
Hello guys!
My bike is leaking oil from the clutch push bar oil seal.
I am not sure if this is the original oil seal or if something that the previous owner put to solve the problem.
I am buying the original oil seal but before I take the bike to a mechanic I need to know if is necesary to open the engine or not to make the change.
If not, do you thing I can do it by myself?
Sorry for my english, I am from Argentina.
Best
Esteban
Online Nebr_Rex
Re: KZ400 oil leak - clutch push rod oil seal
« Reply #1 on: Dec 25, 2017, 22:17:05 »
The cases will have to be split to replace the seal.
As far as I know that seal is no longer available from the dealer.
I have seen a valve stem seal used. The valve seal for this engine
[and most other Kawasakis of this era] is 7mm. The same size
as the clutch push rod. It is attached to the old seal to prevent
leakage around the push rod.
Offline saviola8
« Reply #2 on: Dec 26, 2017, 14:45:09 »
I look for the oil seal on ebay and there are plenty of choices to get one. It is like 100$
So. You are saying that I have to open the engine to replace it?  :-\
Online Nebr_Rex
« Reply #3 on: Dec 26, 2017, 20:19:24 »
$100 because there are no more.
Yes the cases have to be split.
