Author Topic: Gsxr forks for kawa  (Read 1084 times)
morgs88
  • Guest
Gsxr forks for kawa
« on: Jan 01, 2018, 17:33:07 »
Hello, next project is a Kawasaki gt750..
Very warming to the ideal of the Suzuki gsxr 750/1000 upside down forks.
Have seen them on Honda cx various times. But has any one idea if they would fit a Kawasaki..... cheers
Offline SF
Re: Gsxr forks for kawa
« Reply #1 on: Jan 01, 2018, 17:46:24 »
Contact Cognito Moto
72 R5
75 CB550 PROJECT
72/73 S2 RACE BIKE
72 CB350 MOM'S BIKE
Offline VonYinzer
« Reply #2 on: Jan 01, 2018, 18:22:25 »
https://www.allballsracing.com
No modern forks "fit" vintage bikes, but they can be mounted. It really plays with the take and trail (hence kits like Cognitos triple trees) so you need to do some proper planning to keep the bike safe to ride.
Offline Streetfighterkz
« Reply #3 on: Jan 01, 2018, 18:26:06 »
Anything will fit but the amount of work it takes can vary. You may get away with just a steering bearing swap but my guess is the Gsxr steering stem will be too short for proper thread engagement.  You may be able to swap your Kawi stem into the Gsxr lower triple clamp by welding or bushing then welding it. Or you can do like SF suggests and have Cognito Moto or another custom machining company design all the necessary pieces for you.
Whatever way you choose, take the drastic reduction in ground clearance into consideration.
Later, Doug
'78 Kz1000
'76 Kz900 'Stripfighter (work in progress)
'83 Gpz750 (work in progress)
'89 V-Max
'89 Gsxr750 Trackfighter
morgs88
  • Guest
« Reply #4 on: Jan 02, 2018, 12:21:13 »
Are the forks that much shorter??
« Reply #5 on: Jan 02, 2018, 14:20:00 »
They’ll most likely be around 1.5” or more shorter. Plus if you’re switch to the 17” wheel you’ll lose another 1” there too.
Later, Doug
'78 Kz1000
'89 V-Max
morgs88
  • Guest
« Reply #6 on: Jan 02, 2018, 14:21:19 »
Later, Doug
Can afford to lose a inch or so on the bike!
Shame I can’t gain it else We’re and keep the misses happier
Offline CrabsAndCylinders
« Reply #7 on: Jan 02, 2018, 16:15:39 »
I hear ya, buddy. ;)
Lighter, Quicker, Faster.
Offline irk miller
« Reply #8 on: Jan 02, 2018, 20:02:43 »
Here's a chart that gives you actual measurements to compare instead of guessing whether something will or will not work:
There's an 18mm difference in length between 600 and 1000 forks, for example.  If you have a press, it makes it way easier to do the swap if the stem lengths don't jive.  600 and 750 steering stems are 257mm.  Not sure about the 1000s.
Don't forget, there's also CBR and R1 and TL1000r to consider.
morgs88
  • Guest
« Reply #9 on: Jan 03, 2018, 02:35:21 »
Thanks irk miller legend
