Author Topic: CAFE CREME - BOARD.....TRACKER  (Read 5252 times)
Offline beachcomber
  • TJ - Beachcomber
Re: CAFE CREME - BOARD.....TRACKER
« Reply #30 on: Feb 10, 2018, 08:40:00 »
Thanx for the encouragement Limey. I managed to get a headstock from a guy in Ireland - so that will save me 80 or so having one made ! Once the forks are "free standing" I'll mock up the forks into the new headstock and see where I want the frame tubes to be. It's at times like these that I wish my welding was better than the "bird shit" variety ! ::)
I now have all the new / refurb parts for the forks - bushes, seals, fork nuts, new  [ !! ] springs, etc.,etc. but there'll be a full mock up first. I've decided to save myself some money and spray the components. definitely some sort of Coffee Cream for the cycle parts with Cream highlights - maybe wheels [ as the chrome / alloy is very good ] but definitely the engine [ yes ], handlebars and probably tank - IF I decide to spray rather than keep the 100 + year old patina.
Offline beachcomber
  • TJ - Beachcomber
« Reply #31 on: Feb 10, 2018, 19:20:55 »
Final leg of the POC mock up. The RAMSHOX unit will fit snugly in here. Alloy plate - nicely machined if I can - to support the top pin and bolted through the threaded locating holes.
Offline beachcomber
  • TJ - Beachcomber
« Reply #32 on: Feb 12, 2018, 15:37:43 »
Final position for shock - all measured up now and bend ordered for the front springer hoop. Honda spindle measured up to be shortened and re-threaded.
Offline beachcomber
  • TJ - Beachcomber
« Reply #33 on: Feb 14, 2018, 12:12:05 »
My pal Brian [ build buddy ] is now obsessed with having Brass highlights - nuts etc. he's just finished the template for the top yoke cover - in 3 mm Brass ! I'm trying to find someone who can etch in "Cafe Creme"  8)
BTW - the fact that the holes are obviously out of line is NOT Brian - but the good old factory workers at BSA ! ::)
Offline beachcomber
  • TJ - Beachcomber
« Reply #34 on: Feb 15, 2018, 17:57:48 »
Last few pieces of the forks jigsaw. The Bantam headstock [ 10 ] and the 5/8" weld bungs and clevis' for the springer loop.
Offline beachcomber
  • TJ - Beachcomber
« Reply #35 on: Feb 19, 2018, 11:41:39 »
The special RAMSHOX unit now mounted and functioning as I envisaged.  ;D Good to have mates eh !!  ;) The springer hoop should be here this week so the front end design can be finalised.
Both Mitas "period" tyres have arrived now and the old knobblies removed from the wheels - decision made they will be powder coated - Buttercream. Just trying to get the right "flavour" for the contrasting Coffee Cream colour !
Offline beachcomber
  • TJ - Beachcomber
« Reply #36 on: Feb 19, 2018, 17:40:52 »
I'm thinking of getting the La Francaise Diamant tank reproduced in ETHANOL PROOF fibreglass. Originally it was a back up plan in case the real one ever got damaged, but I've had 2 people interested. I would need to get interest in 5 so I can get an accurate quote.
Offline beachcomber
  • TJ - Beachcomber
« Reply #37 on: Feb 22, 2018, 09:49:48 »
Finally got the old fork bushes out ... what a mission ::).  All ready for re-assembly with the new bushes now. The springer hoop arrived this morning and I've done the final POC mock up - all seems OK. The weld bungs just need a gnat's out of the bore to be a good press fit on the hoop prior to welding. It's a mad rush now to get as much done before my pal is off to the US for 3 months.
Offline beachcomber
  • TJ - Beachcomber
« Reply #38 on: Feb 24, 2018, 17:58:27 »
FINALLY DID A POC MOCK UP WITH THE KZ MOCK UP ENGINE ............................. just doesn't have the right period look I'm after.  Anyway, up pops a 250cc Virago complete bike on E-Bay for the right money. All up and running with a long MOT [ Test ]. I've worked out that even conservatively I can sell off all the bits I don't need and end up with all the bits I need as freebies ! This is a German built 125 Virago to give you an idea.
Offline Luugo86
  • '73 CB350, '78 XS650 Cafe Killer
    • ToadStool Cycle Co.
« Reply #39 on: Feb 24, 2018, 19:23:32 »
I've been wanting to do a boardtracker with one of those little 125/250 Vtwins for a while now.
Live to Die, Die to Live
