Author Topic: CJ360 Build (my first)  (Read 7647 times)
Offline irk miller
Re: CJ360 Build (my first)
« Reply #30 on: Jan 18, 2018, 08:47:04 »
Or, since the engine is already open look at the one you have and make sure it's the updated tensioner.
Offline ZenMoto
« Reply #31 on: Jan 18, 2018, 14:54:06 »
That assumption is based on the beating the case has taken from the cam chain:
Maybe that's normal? ...my first time in one of these engines.
Is this the engine number you're referring to? If so, there are no dots.
And this is the tensioner I pulled out:
I'm not sure the difference between that and the updated one (time for more net research).  lol
Thanks again for all the advice guys. ...which reminds me, what is the trick with the neutral safety switch wire? I couldn't, for the life of me, figure out how to disconnect it and it eventually just snapped off at the post while I was fooling with it. Seems to be some kind of a spring, so I thought maybe it was just pinched in, or wound around the spring ...or something bizarre like that!  :-[
Offline Sonreir
  • Moderator
  • Oregon
« Reply #32 on: Jan 18, 2018, 15:01:39 »
IIRC, the CJ models all had the new cam chain tensioner. A bit of wear on the inside of the cases in normal to see, but I'm not certain the engineers intended it that way. Just make sure you keep things adjusted properly. Take care of the adjustment every time you change the oil (along with valve clearances and ignition timing) and you'll be good.
The tensioners have a spec in the manual, I think. Most folks get 10,000 - 15,000 miles from a set.
Audaces fortuna iuvat.
1977 Honda CJ360 - Caf SOS - Stage One, Caf SOS - Stage Two
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline irk miller
« Reply #33 on: Jan 18, 2018, 15:16:19 »
The opening on the curls at the ends of the recall tensioner faced forward where yours faces backwards, and the rubber had a shallower profile.
Offline crazypj
« Reply #34 on: Jan 18, 2018, 23:32:35 »
Yep, ALL CJ's had the 'new' tensioner.
That wear isn't normal, it's caused by bike never being serviced (probably missed the first one and just got oil change - maybe?)
 You may need to split cases to un-stick tensioner 'horseshoe' severely loose chain damages the pivot so it can't move. I have pics of damaged one somewhere in 'Build to Blog' thread. I used a Firefox add on which was working a few days ago
Best thing I ever overheard
Brian Morgan, 1982
Offline ZenMoto
« Reply #35 on: Jan 19, 2018, 01:28:16 »
Thanks again PJ, Im planning to do a full tear down anyway, so Ill make sure everything is good to go. Reading up on it, Ill bet youre right, the tensioner is probably fine, but has likely never been adjusted.
Offline Integra99
« Reply #36 on: Jan 19, 2018, 07:40:20 »
I have this issue with my CB400f popped on a new Cam chain but the horseshoe is stuck.. she runs lovely but I will have to split the cases to sort this once it starts to stretch. I'll only do 500 - 1000 miles in a year so it will be ok for a bit I hope.
Offline crazypj
« Reply #37 on: Jan 19, 2018, 12:30:24 »
I checked my CB360's Build to Blog thread, some of the pictures still don't work and some I downloaded then deleted. Photobucket can GFT
Haha yes,  In bed by 9 and up early...Its what old people do.   :P
STFU, your younger than me
« Last Edit: Jan 19, 2018, 12:33:49 by crazypj »
Brian Morgan, 1982
Offline Turnturtle
« Reply #38 on: Jan 19, 2018, 13:01:00 »
Here is the link for the cam chain tensioner recall Service Bulletin for your reference.
http://www.hondatwins.net/forums/47-manuals-technical-documents/4382-360-bulletins-re-posted.html
Offline ZenMoto
« Reply #39 on: Jan 23, 2018, 17:14:00 »
Thanks again guys. Not much to update as it was a crazy busy weekend. ...but I did get to work on stripping the CB360 tank I had picked up. Turns out, what looked like two different coats of blue turned out to be two different coats of blue, over a silver (which I though upon early paint stripping was the base metal) ...over what can only be described as a body filler "dip" ...over the expected bondo to fill in the areas where the logo mounting would be, ...over the original teal-blue color.
Anyway, I should have taken a later photo where I got the tank mostly down to just the "skim" coat of body filler but I failed to take the photo as my arms were shot from scraping, and sanding (seriously, it was like 1/8" thick with this white body filler).
Eventually I gave up and took the damn think to a local media blasting & powder coating shop, and should have it back later today to see what damage was being covered up. ...fingers crossed it's salvageable.   :o
« Last Edit: Jan 23, 2018, 17:15:33 by ZenMoto »
