Author Topic: 71 CB450 Urban Hooligan Tracker  (Read 1896 times)
Offline 1fasgsxr
Re: 71 CB450 Urban Hooligan Tracker
« Reply #10 on: Mar 26, 2018, 18:35:46 »
Tire to swing arm clearance too
Offline TheBraps
« Reply #11 on: Mar 29, 2018, 12:46:14 »
Looks great so far. I don't believe a 150 rear will fit in a CB360 swingarm though. Chain to tyre clearance would be an issue too.
Yeah did some more research and I will have to go with a 140/60
Offline TheBraps
« Reply #12 on: Mar 29, 2018, 12:52:31 »
Got the CB350 hub in and started cleaning on it. I need to hit it with some brake cleaner and some soft brass brushes to finish it up before I send it over to powder coat. I have new brake shoes, springs, bearing and sprocket to put back on it when it comes back.
Gotta take the swing arm over to a buddies show to use his media cabinet to clean it up.  Should I do the brass bushing while I am at it?
« Last Edit: Mar 29, 2018, 12:59:42 by TheBraps »
Offline Pete12
« Reply #13 on: Mar 30, 2018, 18:20:12 »
If your buddies blaster uses glass bead then don't do the brass bushes...
Offline MiniatureNinja
« Reply #14 on: Mar 30, 2018, 19:03:40 »
depending on the tire selection
I had a 130 tire on a cb360 and it was less than 1mm clearance of the chain. if you did a 520 conversion, you could be a little better off.. but I doubt a 140 will work
'75 Honda CB360 - thread
Offline TheBraps
« Reply #15 on: Apr 02, 2018, 10:44:51 »
Will be lengthening the rear swingarm by 2.5". I have talked to Devin over at Cognito Moto about what it takes to fit the fatter tire. Rear shocks will go to 14+"
Offline TheBraps
« Reply #16 on: Apr 02, 2018, 10:47:04 »
It does use the glass beads. Can I do the brass bushing and just rebuild the swingarm after?  I mean tear it down, media blast, clean and then put the bushing in?
Offline WhyNot
  • ~~~If it ain't raining, I'm riding~~{iii}?~~prost~
« Reply #17 on: Apr 02, 2018, 13:15:11 »
Man I'm in on watching this build.
I like the way it's looking.
Good job so far.
2006 Harley Davidson Heritage Softail
1975 Honda CB750K5 needs carb work
1974 Honda CB350F2 needs tins painted (being lazy)
1972 Honda CB175K2 roller no engine
1972 Honda CB/CL350 Engines need roller
1972 Honda SL350K2 Frame for above engine
1972 Honda CB100K2 needs kicker shaft
1990 Mitsubishi MM needs engine rebuild
1984 Dodge D50 Beater DD since 1997
Offline Pete12
« Reply #18 on: Apr 02, 2018, 18:29:52 »
Glass bead gets imbedded in material, particularly something as soft as brass, and will wear it out very quickly once reassembled. If you mean doing the swing arm without the brass bushing in place, then no problem at all.
