Author Topic: 71 CB450 Urban Hooligan Tracker  (Read 2153 times)
Offline TheBraps
« on: Jan 12, 2018, 15:46:36 »
I picked up a 71 CB450 last year and finally decided to start stripping it down to build a retro urban hooligan tracker. I have an idea of what I want it to look like. In the end when I am done with the build I will either sale the bike, raffle the bike off or donate it to The Fisher House Foundation for them to use in a charity event. Either way it goes all proceeds from the bike will be going to Fisher House Foundation. I look forward to searching these forums for help along the way. I will use this post to track my progress.  As this is all out of pocket for me with no sponsor ships looking to drag this out over the entire year of 2018. I have already done the swap to a 2003 GSXR 600 front end, removed the dents from the tank and primered, cut the rear end off the bike, detabbed the frame and light primer.
Date of Purchase
Currently
Offline TheBraps
Re: 71 CB450 Urban Hooligan Tracker
« Reply #1 on: Jan 16, 2018, 16:03:52 »
New top triple clamp with riser mount holes drilled from Cognito Moto ordered, Pro Taper Contour bars (CR High bend) and Pro Taper Pillow Top Lite grips ordered all on Friday of last week. Will be picking up the riser mount for the motoscope mini from Cognito Moto to fit the motoscope mini and motosign indicator lights in. Bars and grips will be here tomorrow no shipping info from Cognito Moto yet. ASV perches and levers along with original Honda bar switches will finish up the controls on the bars. Going to fabricate up a front facia (number plate style) with LED headlight assembly built in. Thinking of running M-Blaze turn signals up front and they will be what holds the number plate to the facia mounts.
Offline TheBraps
« Reply #2 on: Jan 18, 2018, 14:17:07 »
What are the cons of doing the CB360 rear swinger swap?  Plan on using the CB360 rear swingarm and hub to have a 36 spoke wheel. Other than the swingarm being longer(think maybe a set of longer shocks can help with this) and the axle being smaller, what are the cons?
Offline LiamG6
« Reply #3 on: Jan 24, 2018, 21:19:22 »
None, it is plenty strong, everything basically the same just slightly longer. You could argue the angle of the shocks is less ideal but it really is no issue. The lighter hub is a plus. You've switched your front end so your wheelbase and handling characteristics have changed but longer swingarm should help keep it stable. I've done same swap with CBR600 F4i front end.
Offline TheBraps
« Reply #4 on: Jan 30, 2018, 16:40:32 »
Thanks.. that is exactly what I was hoping to hear. I just blew another grand at Cognito. Talked to Devin over there and it seems Fox is no longer doing the Podium R series shocks. Anyone ever got any of the Ohlins STX series to work on the Hondas?
As soon as these orders come in from Cognito I will have some update pictures.Should have the CB360 rear soon-ish then I gotta get the hub and brake cleaned up ready for powdercoat and lacing it to a 17x4.25 warp 9
« Last Edit: Jan 30, 2018, 16:42:39 by TheBraps »
Offline canyoncarver
  • 'hacking is learning'
« Reply #5 on: Jan 30, 2018, 16:49:06 »
Neat purpose to the build.  I'm in.
Offline TheBraps
« Reply #6 on: Feb 01, 2018, 11:22:17 »
Yeah the wife and I did a fundraiser for Fisher House about 3 years ago, we raised 18k for Fisher House and 10k for the family of a fallen Master Chief. Figured it was time to do another fund raiser for them.
Top triple from Cognito Moto came in yesterday. I have a few bits I am still waiting on to get the front end up as a roller. Once those come in I will do a video and post it on YT.
« Last Edit: Feb 01, 2018, 11:25:04 by TheBraps »
Offline TheBraps
« Reply #7 on: Feb 22, 2018, 15:32:04 »
Made a lil bit of progress. Got the front wheel in from Cognito Moto, still need to get rotors and get the tire mounted on it.
Got the new top triple clamp and bar riser mount from Cognito Moto installed along with the Protaper Contour bars.
Tires and rotors are on order trying to source a good CB350 swingarm, axle, adjusters and rear hub with brake plate. Looks like Fox stopped making the Podium R shocks so probably going to end up with Ohlins on it.  Once I have a rolling chassis will start the fab work for the rear hoop, rear cowl and front number plate with integrated headlight.
Offline TheBraps
« Reply #8 on: Mar 21, 2018, 20:34:17 »
Finally got the tired mounted to the new wheel. Still need rotors and calipers for it. Up next will be swapping to a CB350 rear swingarm and wheel. Going to lace the CB350 hub to a Warp 9 17x4.25 and mount a 150/70x17 rear tire. After that will start the fabrication for the rear cowl, hoop, electrical tray and front number plate with headlight.
Offline LiamG6
« Reply #9 on: Mar 26, 2018, 13:43:05 »
Looks great so far. I don't believe a 150 rear will fit in a CB360 swingarm though. Chain to tyre clearance would be an issue too.
