Author Topic: New Age Cafe Racer - Honda CB750 -79 from Finland  (Read 7967 times)
Offline Marcushyden
Re: New Age Cafe Racer - Honda CB750 -79 from Finland
« Reply #70 on: May 19, 2018, 07:21:01 »
All the parts for the first startup is now ordered and should arrive in next week.
I ordered a new neutral switch, an oil pressure switch and a small diode for the main wiring.
All the hoses, filters and wires has already arrived.
New coils, sparkplug wires and -caps
All main wires are connected. (battery->ground / battery->starter relay / starter relay->startermotor)
I have red from multiple forums about regulator location.
I'm going to move the regulator from the tray to outside to get some air.
Have to figure out where to put it...
Location of the licenceplate... Well had to make decicion and the plate found place side of the bike.
Workshop machined 1/3 off from the bracket so it have a step in the bracket and can be locked to end of the rear swing.
Licenceplate lights
I was bored so I made these carbonfibre plates to cover front fender fastening points.
I picked up my clip ons from the workshop.
They drilled inner hole longer and made hole to the side so I can get front turn signal wires out.
This is the final setup
For the final setup we changed few things:
I made new metal sleeve that goes straight through to mirror. To this sleeve we made threads so it can not rotate.
Also we drilled the locking pin through mirror and that sleeve, so the mirror can not rotate on the sleeve.
At this point it might work  8)
Offline Marcushyden
« Reply #71 on: Jun 02, 2018, 06:19:36 »
Fuel lines done
Fuel line from the tank -> fuel filter -> carbs.
It was little tricky to figure out where and how to put fuel filter without too much "uphills" and turns to the hose.
I used pipeclamp with rubber insulation to hold fuel filter in its place
Coating the tank
The fuel tank is old and has little rust inside. When I filled it with water, it was all over rust-colored when I poured it out.
Also you could hear little crumbles rolling around at bottom of the tank.
I bought Por15-kit.
First I have to say you all who are planning to do this: the process is from hell and takes huge amount of your time  ;D
First instructions advice you to flush the tank with fresh water to get bigger particles out straight away.
Remove every removable part (petcock, fuelcap etc.)
After that you have to clog all holes excluding filling hole.
First issue comes at this point. As you may know or guessed, these duct tapes doens't hold when you are going to use hot water...
My advice to you is to fabricate pieces from a sheet metal or something that you could bolt tightly to cover holes.
1. step in the real process is to put Marine Clean in. Add same amount hot water.
This will remove grease and other not-wanted-stuff.
After that seal filling hole and pray it will hold  ;D
I shaked the tank about 15 to 20 minutes and after that I let it stand 10 minutes on its each side.
Finally flush it with fresh water to get all cleaner out
2. step is to put Metal Prep in. It will prepare metal to receive coatingliquid.
Same process again. Clog holes, metal prep in, seal the filling hole.
I shaked the tank approx. 20 minutes and after that let it stand 20 minutes on each side of it.
Finally flush it good with fresh water. Even the last drop of metal prep has to get out.
After this you should get the tank 100% dry and fast as possible.
I took the tank outside to the sunlight... (its been crazy May in Finland. Temperature between 24 to 28 celsius. Normally we would talk about 15 celcius)
I shaked most of the water out and finally put hot air blower to heat up. (you are not allowed to use compressed air)
Last phase its coating
Before you clog holes one last time, you should put bolts in, because coatingliquid will coat up threads also.
You should not shake the canister, because it would produce some air bubbles and you don't want them. Although you have to stir it well before using.
Liquid in, seal holes and gently rotate tank all around.
Many times I thought will this work and will it cover all edges and sides of the tank.
Apparently liquid is pretty "smart" and will expand all over the tank.
After rotating 15 minutes I poured excess liquid out and cleaned outside spills asap.
You should use gloves because this stuff will be in our hands atleast two weeks  ::)
It will dry 96 hours and after 7 days you can put gasoline in.
These pics are after two days of drying and as you can see, some air bubbles formed during the last phase.
Surface looks good
I'm not sure did I post picture of this already, but my friend from the states dropped me cognitomotos gearlever adapter.
In these pics adapter is in wrong way because gear selection order is upsidedown.
What comes to wiring this beauty, new diode arrived...
...new neutral switch...
...and new oil pressure switch.
We are now going through wiring and this picture shows my mood atm
This wiring sh*t is not my cup of tea.
But will see...
Offline Marcushyden
« Reply #72 on: Aug 21, 2018, 03:54:35 »
Two and half months since last post...
Positive progress has happened but lately some negative things also
Wiring this bike was pretty difficult for me and finally I made a decision to buy a m-unit with goodies
Set included m-unit V.2, m-switches and m-button
With these great items I figured out wiring and also made it very easy.
Finally bike was ready for her first start up
I might have told you but this bike hasn't been running since year 2000.
Its 18 freakin' years!
Well that day came and after long time period of trying, it finally came alive.
I was so nervous but happy after everything.
Here is a short video of its very very first start up.
What about those negative things...
Time. As you all know, time is one of the hardest thing to control.
This project should be on the road if you ask me, but our time is limited and first thing where you see it is here in this project. Unfortunately.
It was greatest summer in Finland that I have ever lived, so I was more in to other things than this project.
Next big thing is location. Bike is currently in my parents house 18km away from my home or from my work.
You don't just go and do few things for a hour.
By now it looks like this bike is not going to be driven this summer/autumn, so I think I will have my own garage opened again in autumn.
After that it is easy to take few stairs and go to do something.
New problem came when we noticed that lower cylinder gasget is leaking a lot.
This mean I have to open the engine again and change that gasket.
Motivation level just dropped to zero  ;D
Someone could say "this is motorsport" and I think that someone would be right.
Also two carbs was overleaking and we found out that needlevalves were faulty. Ordered new ones and changed them. Doesn't leak anymore.
My to do -list is simply and ready so I know exactly what to do and everything is already planned.
p.s.
Do you know any companys around Europe that could make customlength cables for throttle and clutch?
Not feeling right with original long ones.
