Author Topic: 75 CB360 - bad omen "yatagarasu" build  (Read 39874 times)
Offline MiniatureNinja
Re: 75 CB360 - bad omen "yatagarasu" build
« Reply #160 on: Mar 27, 2018, 14:35:56 »
I edited previous post.
Exhaust is way to short if it's exiting around swing arm pivot point, your not going to run open pipes (could be interesting with 125~130 secondary mains on a dyno to see just what it can do) I would guess around 41~42bhp at te wheel (compared to 36 at the crank that Honda claimed)
CB350's dyno around 26~28bhp, 360's 24~30 at the wheel (obviously more production variations on 360)
oh no, I know these bikes like long exhaust - I plan to have the exhaust come under the frame then right at the back of the frame kick out and up to two reverse cones - I posted a picture of my idea earlier in this thread
EDIT: got piston rings end gapped - now just waiting on the gasket I ordered to arrive and my cylinder head to be done so I can throw this all back together!
« Last Edit: Mar 27, 2018, 18:44:32 by MiniatureNinja »
'75 Honda CB360 - thread
« Reply #161 on: Mar 29, 2018, 00:24:25 »
OK
so I owned up to my mistakes thanks to members here for steering me true!
EDIT: I REALLY hope you guys approve because i DON'T wanna do this again.
note: I plan to weld a 12mm bar all the way through and then cut in the middle between the frame - so that it's straight and I will drill a hole in the ends for a 6mm round head bolt and washer to mount the shocks
chopped off the stupid shock mounts I was so proud of...
welded "proper" ones this time
mocked up how the seat and cowl will look:
I did a bunch of other stuff but I am dead tired and will post more tomorrow
« Last Edit: Mar 29, 2018, 00:37:59 by MiniatureNinja »
Offline teazer
« Reply #162 on: Mar 29, 2018, 01:30:08 »
Much better.
Offline WhyNot
  • ~~~If it ain't raining, I'm riding~~{iii}?~~prost~
« Reply #163 on: Mar 29, 2018, 08:59:43 »
Absolutely better......but I'm no welder, wish I could though.
Maybe someday I'll take a class and buy a cheap welder.
1975 CB750K5
1974 CB350F
Offline crazypj
« Reply #164 on: Mar 29, 2018, 14:47:43 »
Just buy a cheap welder and make a lot of mistakes  ;D (just make sure your not doing anything structural until you figure it out)
A lot of cheap 'buzz box' welders turn up at garage sales and Craigslist and a LOT of good work has been done without using TIG, MIG or expensive welders. It is easier with a multi adjustable box plus the learning curve isn't as steep. Welding takes practice more than anything else. Long long time ago (probably around 1975~76?) my brother bought a cheap 100A 'buzz box'
After a few months (and several pounds of electrodes) I was able to weld any steel you will find on a motorcycle I most proud of repair to rear mudguard mount on Honda S90 he had, it was only about 0.018"~0.020" thick.(someone with an S90 probably knows gauge  ;D ) Looked like TIG (which I hadn't even heard of at the time) Being a kid helped as well, you don't know you 'can't do that' so you just do it  8)
Best thing I ever overheard
Brian Morgan, 1982
Offline WhyNot
« Reply #165 on: Mar 29, 2018, 15:14:45 »
Funny story........been watching the local and not so local cl, haven't found anything.
Working every day of the week don't get time for yard sales.
Got any recommendations for a cheapie at HF. That's my only go to source at the time?
Thanks for the help, and sorry for the momentary threadjack mini.
1975 CB750K5
1974 CB350F
« Reply #166 on: Mar 29, 2018, 15:24:52 »
the vulcan welders from HF have been getting pretty great reviews from professional welders on youtube - I bought their migmax 215 and it's on backorder... they are always out of stock, seams to be a very high demand for them as they are VERY good for the price.
went to the local napa and bought a firepower 165 - it's a 230v 50amp welder - I could have spend half that getting a cheaper one and spent the rest on classes and be much better at it.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #167 on: Mar 29, 2018, 15:28:15 »
FWIW I use the Harbor Freight (Chicago Electric?) MIG 170, which runs on 220v. I use gas with it and have had great results.
Offline WhyNot
« Reply #168 on: Mar 29, 2018, 15:34:20 »
Only place I have 220 is at the dryer.
So, I'd have to get a 110.
Thanks
1975 CB750K5
1974 CB350F
« Reply #169 on: Mar 29, 2018, 16:46:17 »
Thanks
that means you already have a 220 breaker... just run a new wire to a new outlet, that's what I did - only 230 I had was at the electric range
