Author Topic: 75 CB360 - bad omen "yatagarasu" build  (Read 32004 times)
Offline crazypj
Re: 75 CB360 - bad omen "yatagarasu" build
« Reply #280 on: May 16, 2018, 12:28:45 »
My father always told me " add lightness and simplicate'  ;D
Best thing I ever overheard
Brian Morgan, 1982
Offline MiniatureNinja
« Reply #281 on: May 16, 2018, 14:54:23 »
"Nothing is lighter than a hole" is my favorite thing I've heard.
Also, is it possible to push the cam chain tensioner down through the top of the case without splitting the case or using the "pushbar pulling tool" ?
I added a couple mounts for the aluminum electronics tray, didnt have enough carbon fiber to make a new one so I had to use aluminum.
Those "rails" along the frame will hold the seat in place
I'm getting better at welding
'75 Honda CB360 - thread
Offline jpmobius
  • where does this go?
« Reply #282 on: May 16, 2018, 20:06:31 »
using Titanium is nuts unless people can see it and admire your excellent tastes and previously deep pockets.
Wisdom!  I've had competitors that needed your consulting services - you can talk them out of the hundreds of dollars of titanium fasteners "aloft" in the rig of their 10,000 lb sailboats so I can find them a more appropriate home on my pick up!
Welds are indeed looking improved!
« Last Edit: May 16, 2018, 20:10:27 by jpmobius »
Mobius
« Reply #283 on: May 16, 2018, 23:40:49 »
If proboltusa.com sold the right length 10mm bolts for my engine mounts I would be using them. Lol.
Valves in! Getting closer. Yes they were leak tested, poured a small amount of acetone in the ports, none leaked out. I thought I would have to lap them, but the machine shop that did the seats did it for me, which I thought was nice of them.
Oh by the way, notice the oil stain lines on the head inside the reservoirs? Bike only had a side stand... haha
« Last Edit: May 16, 2018, 23:42:20 by MiniatureNinja »
Offline Sonreir
  • Moderator
  • Oregon
« Reply #284 on: May 17, 2018, 11:57:02 »
Lapping valves is a lot less common these days. Machining and tooling is more precise than it used to be, so if the valves had to be lapped at all, that would be unusual. Not necessarily bad, but it should raise eyebrows.
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
« Reply #285 on: May 17, 2018, 12:22:21 »
oh, well that makes sense then. I didn't lap them because I forgot my lapping compount at the shop and engine is at home - I used some prussian blue, they came out perfect, so I did the leak test... they were perfect. I assumed he lapped them but what you said makes more sense
Offline crazypj
« Reply #286 on: May 17, 2018, 17:23:07 »
On most modern engines you can't lap valves as the hardening isn't deep enough and will wear off to softer material underneathe
As for cam chain tensioner, yes, you can use a long bar from top. Make sure to radius end so it fits into cup on bottom. Loosen adjuster with bar in place and see if it moves up any further.
Brian Morgan, 1982
« Reply #287 on: May 19, 2018, 17:58:58 »
Ran into a snag. In my haste and inexperience, I overlooked the fact that I would need the updated top tensioner hold down for the new tensioners. Amazed that NONE of the people that sell this part make it clear that if you are updating this on an old motor you NEED To source the correct holder and probably a rubber bumper too. That item should be here Wednesday and I can get to buttoning up the motor.
Frame fabrication is done, so I painted it satin black with VHT rollbar and chassis paint. I would have loved to get it powdercoated but let's not go there... only one place has a cabinet big enough to sandblast this frame and they want $400 to do the work. no!
Offline Alex jb
« Reply #288 on: May 20, 2018, 17:05:48 »
That looks pretty darn good
If you intend to ride the ass off it, it’s going to get some wear and tear and chips anyway, a well loved/used bike is a noticeable step away from pristine trailer queen.
« Reply #289 on: May 20, 2018, 17:16:01 »
Yea I dont want it to be a trailer queen but I do want it to look proper. I don't like a rat bike look. As it is I am way behind on the project and dont have time to devote to painting the tank, so its gonna be looking like a rat bike for some time. I did check all my valve and piston clearances today. .060 on the intake and .070 on the exhaust. I have a feeling that's cutting it close to acceptable but it will do for me, running a 50/50 mix of pump and race gas, and the lighter pistons shouldn't stretch as much. Also did a engine mock up because I needed some morale and so I put a couple coats of "looking at it" on the engine as the doghouse guys would say
Looks good, but also noticable wear on the paint and I'm ok with that. When I show up to the bike show next Tuesday it wont look like i just built it. LOL
« Last Edit: May 20, 2018, 17:20:21 by MiniatureNinja »
